I have successfully setup VPN connection to my home network. While I am able to access my HTPC-SERVER's (running Win7 64-bit) shared ressources using its static IP, I cannot access it by referring to its UNC name ("\\HTPC-SERVER").
Also, Explorer's network-section does not list the network's resources.
Everything works fine when connected to the LAN-side.
The above issues are the same no matter if I set up the HTPC-SERVER to act as VPN-server (with proper port forwarding in my router), or if I use my Asus RT-N66U router as VPN-server.
Router's IP is 192.168.15.1, subnet mask is 255.255.255.0 and acts as DHCP-server with IPs in the range of .2-.200. The router's VPN server gets to allocate IPs in the range .200-.209. HTPC-SERVER's IP is static and set to 192.168.15.10 in the router's DHCP-table.
When connected over VPN, IPCONFIG /ALL says:
C:\Windows\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Lenovo_X300
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter VPN Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VPN Connection
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.15.200(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 192.168.15.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Network Bridge:
Description . . . . . . . . . . . : MAC Bridge Miniport
Physical Address. . . . . . . . . : 02-1E-37-90-40-D3
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::9d7e:1c15:6324:21d2%15(Preferred)
IPv4 Address. . . . . . . . . . . : 172.20.10.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.240
Lease Obtained. . . . . . . . . . : 4. oktober 2014 10:23:48
Lease Expires . . . . . . . . . . : 5. oktober 2014 10:09:24
Default Gateway . . . . . . . . . : 172.20.10.1
DHCP Server . . . . . . . . . . . : 172.20.10.1
DHCPv6 IAID . . . . . . . . . . . : 419569467
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-C5-25-4F-00-1E-37-90-40-D3
DNS Servers . . . . . . . . . . . : 172.20.10.1
Tunnel adapter isatap.{E78F7DD1-2527-480A-9311-10289FADDE03}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{6840F7EB-AAE1-466F-829A-A4E05F7F92B9}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:87c:3ef1:3f57:f037(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::87c:3ef1:3f57:f037%14(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Any help would be much appreciated.
Regards
Anders
rred)
Regards
Anders
