FBI Surveillance Van #2
I think I figured it out.
I'm in Windows 10 Pro version 2004.
I went to "Settings" then "Network & Internet" then at the bottom of the "Status" page I clicked "Network Reset." Then when the "Network Reset" page open, I clicked "Reset Now." In the notes above the "Reset Now" button it says that your PC will be restarted, but mine did not automatically do that, so I restarted it manually. I then waited while my PC reconnected to my WiFi network (I did nothing with the PC during this time), and then once it was reconnected, I opened my browser and typed "router.asus.com" and the router's GUI appeared.
I use a VPN, so I always have to disable it in order to connect to the router's GUI.
Before I did that "Network Reset" thing, I tried releasing and renewing the ip address, but that did not work reliably.
The next thing I'm going to do is log back into my VPN, and then disconnect from it. Then I'll be able to see if that changes my ip address back to the one that won't let me connect to the router GUI. If so, then I guess I'll need to perform the "Network Reset" whenever I want to access the router GUI.
I just connected to my VPN and then disconnected from it, and then I was still able to access the router's GUI.
Hope this helps!
Hope this helps!
