The Doktor
Thanks guys. Installed Merlins latest firmware and all went exactly as the instructions said. Now running firmware 1.0.1.3 & 64k nvram version of Tomato (Toastman mod).
Ed
Ed
After succesfull update cfe i notice that LAN Router MAC Address and Wireless (2.4 GHz / eth1) MAC Address become the same x:x:x:x:x:C0. Before update Wireless (2.4 GHz / eth1) MAC Address was x:x:x:x:x:C2. I tried 30/30/30 without succes, then returned the old value manually.
Used shibby 104 and toastman 5000.5
While merlin was installed i didn't checked mac.
Same here. Is that a problem?
Physically, yes. And they still do, take a look atNormally every LAN device wired or Wifi must have unique MAC address.
# robocfg show
In the router existing 4 Devices....
br0 = WAN
eth0 = NIC-Switch
eth1 = 2.4 Ghz
eth2 = 5 Ghz
I have no idea why eth0 (NIC) & eht1 (2.4 GHz) sharing the Same MAC....
It seems that eth1 is Vlan of eth0...
# ifconfig | grep HWaddr
br0 Link encap:Ethernet HWaddr C8:60:00:E8:XX:YY
eth0 Link encap:Ethernet HWaddr C8:60:00:E8:XX:YY
eth1 Link encap:Ethernet HWaddr C8:60:00:E8:XX:YY
eth2 Link encap:Ethernet HWaddr C8:60:00:E8:XX:ZZ
vlan1 Link encap:Ethernet HWaddr C8:60:00:E8:XX:YY
"robocfg show" should tell you the MAC address of the external device that is connected to that port, not the router MAC!
Is that an Asus motherboard PC onport 1?
...am running Toastmans tomato-K26USB-NVRAM64K-1.28.0500.5 Ext and the mac address is the same for both lan and 2.4ghz radio. So it can't be a CFE upgrade bug.
So what is the command to use to see the router's wireless mac?
Thanks. Will run the command to see results. I am aware of where the IP addresses are but thanks for the information.
| Thread starter | Title | Forum | Replies | Date |
| F | ASUS RT-N66U admin interface not accessible following firmware update | ASUS N Routers & Adapters | 4 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
