After the nvram unset command and a reboot it dosen't give a version output at all now.
A few months ago I implemented displaying the bootloader version in Asuswrt-Merlin's Sysinfo page. I discovered back then that this value doesn't seem to be written back by CFE after you unset it, so I suspected it meant it was only written on a factory default reset, and decided to remove that entry from the Sysinfo page - as it probably meant that it wouldn't be updated if you were to update the bootloader, unless you were to reset back to factory defaults.
It's possible that with a fully 64-KB aware CFE that it would now properly write back the value if it got unset. If that's the case, I might re-add it to the Sysinfo page then.
