connmon connmon - Internet connection monitoring
:) It has appeared.
For the refresh of the web page on the tablet (iPad tested with Safari or Chrome) the only solution is to clear all cache
They'll also update after an hour (Asus' http web server causes images to cache for that long)
HdB342665LNtPFM@RT-AX88U-F098:/www# ls -1 *asp
APP_Installation.asp
AdaptiveQoS_Bandwidth_Monitor.asp
AdaptiveQoS_WebHistory.asp
Advanced_ACL_Content.asp
Advanced_APPList_Content.asp
Advanced_ASUSDDNS_Content.asp
Advanced_AiDisk_NFS.asp
Advanced_AiDisk_ftp.asp
Advanced_AiDisk_samba.asp
Advanced_AiDisk_webdav.asp
Advanced_BasicFirewall_Content.asp
Advanced_DHCP_Content.asp
Advanced_Exposed_Content.asp
Advanced_Feedback.asp
Advanced_Firewall_Content.asp
Advanced_FirmwareUpgrade_Content.asp
Advanced_GWStaticRoute_Content.asp
Advanced_IPTV_Content.asp
Advanced_IPv61_Content.asp
Advanced_IPv6_Content.asp
Advanced_KeywordFilter_Content.asp
Advanced_LAN_Content.asp
Advanced_Modem_Content.asp
Advanced_MultiSubnet_Content.asp
Advanced_MultiWAN_Content.asp
Advanced_NATPassThrough_Content.asp
Advanced_Notification_Content.asp
Advanced_OpenVPNClient_Content.asp
Advanced_OperationMode_Content.asp
Advanced_PerformanceTuning_Content.asp
Advanced_PortTrigger_Content.asp
Advanced_Privacy.asp
Advanced_QOSUserPrio_Content.asp
Advanced_QOSUserRules_Content.asp
Advanced_Roaming_Block_Content.asp
Advanced_SettingBackup_Content.asp
Advanced_Smart_Connect.asp
Advanced_Smart_Home_Alexa.asp
Advanced_Smart_Home_IFTTT.asp
Advanced_SwitchCtrl_Content.asp
Advanced_System_Content.asp
Advanced_TOR_Content.asp
Advanced_TimeMachine.asp
Advanced_URLFilter_Content.asp
Advanced_VPNClient_Content.asp
Advanced_VPNStatus.asp
Advanced_VPN_IPSec.asp
Advanced_VPN_OpenVPN.asp
Advanced_VPN_PPTP.asp
Advanced_VirtualServer_Content.asp
Advanced_WANPort_Content.asp
Advanced_WAN_Content.asp
Advanced_WAdvanced_Content.asp
Advanced_WMode_Content.asp
Advanced_WProxy_Content.asp
Advanced_WSecurity_Content.asp
Advanced_WTFast_Content.asp
Advanced_WWPS_Content.asp
Advanced_Wireless_Content.asp
Advanced_Wireless_Survey.asp
AiMesh_Node_FirmwareUpgrade.asp
AiProtection_Group.asp
AiProtection_HomeProtection.asp
AiProtection_HomeSecurity.asp
AiProtection_InfectedDevicePreventBlock.asp
AiProtection_IntrusionPreventionSystem.asp
AiProtection_MaliciousSitesBlocking.asp
AiProtection_WebProtector.asp
DDNS_info.asp
DNSFilter.asp
Feedback_Info.asp
GameBoost.asp
Guest_network.asp
Logout.asp
Main_AdmStatus_Content.asp
Main_Analysis_Content.asp
Main_ChkSta_Content.asp
Main_ConnStatus_Content.asp
Main_DHCPStatus_Content.asp
Main_IPTStatus_Content.asp
Main_IPV6Status_Content.asp
Main_LogStatus_Content.asp
Main_Login.asp
Main_Netstat_Content.asp
Main_Password.asp
Main_RouteStatus_Content.asp
Main_TrafficMonitor_daily.asp
Main_TrafficMonitor_last24.asp
Main_TrafficMonitor_monthly.asp
Main_TrafficMonitor_realtime.asp
Main_WOL_Content.asp
Main_WStatus_Content.asp
Nologin.asp
ParentalControl.asp
PrinterServer.asp
QoS_EZQoS.asp
QoS_Stats.asp
Restarting.asp
SITE_info.asp
Tools_OtherSettings.asp
Tools_Sysinfo.asp
TrafficAnalyzer_Statistic.asp
UpdateError.asp
UpdateError_reboot.asp
Updating.asp
UploadError.asp
Uploading.asp
UploadingJFFS.asp
WAN_info.asp
WiFi_Insight.asp
aicloud_qis.asp
aidisk.asp
ajax_AiMesh_node_clients.asp
ajax_certinfo.asp
ajax_chk_sta.asp
ajax_coretmp.asp
ajax_ddnscode.asp
ajax_dms_status.asp
ajax_ethernet_ports.asp
ajax_fb_size.asp
ajax_fwdl_percent.asp
ajax_gettcdata.asp
ajax_ipsec.asp
ajax_log_data.asp
ajax_oauth.asp
ajax_onboarding.asp
ajax_openvpn_server.asp
ajax_sysinfo.asp
ajax_trigger_chk_sta.asp
ajax_uploadicon.asp
ajax_vpn_status.asp
ajax_wificlients.asp
ajax_wl_ready.asp
ajax_wlc_state.asp
aplist.asp
apps_test.asp
apscan.asp
automac.asp
blocking.asp
channelcapacity.asp
channels.asp
cloud_main.asp
cloud_router_sync.asp
cloud_settings.asp
cloud_status.asp
cloud_sync.asp
cloud_syslog.asp
configure.asp
cpu_ram_status.asp
detectWAN.asp
detect_firmware.asp
disk_scan.asp
diskmon_test.asp
getAiProtectionEvent.asp
getAppTraffic.asp
getIPSChart.asp
getIPSDetailEvent.asp
getIPSEvent.asp
getNonIPSChart.asp
getTraffic.asp
getWanTraffic.asp
getWebHistory.asp
get_real_ip.asp
get_release_note0.asp
get_release_note1.asp
get_release_note_amas.asp
get_webdavInfo.asp
getfoldertree.asp
getsharelink.asp
getsl.asp
gettree.asp
index.asp
manifest.asp
mediaserver.asp
metrics.asp
multi_vts_rule.asp
remote.asp
result_of_get_changed_status_QIS.asp
start_autodet.asp
status.asp
switch_AiDisk_app.asp
update_IPv6state.asp
update_applist.asp
update_appstate.asp
update_clients.asp
update_cloudstatus.asp
update_customList.asp
update_networkmapd.asp
ureip.asp
visindex.asp
wds_aplist_2g.asp
wds_aplist_5g.asp
wds_aplist_5g_2.asp
zerowaitdfs.asp
Fancy trying the develop branch? After updating, run
connmon startup
connmon startup
Looking good
@Jack Yaz will all these awesome scripts make it to AMTM at some point? I like the idea of having the best of the best all in one neat place - makes it a lot easier to install/update/etc.
This is brilliant! Thank you for your great work.
rumour has it connmon might make the next version ;-)
spdmerlin needs some more refining (namely schedule control) due to people with high speed links experiencing issues. I don't want to tarnish amtm as causing slowdowns when its actually my script (well, a component i use but didn't write)
Ran into similar problems again with the speedtest script, after several hours of running it. Something is really wrong. For some reason, the speedtest results are insanely low. Download was sitting at 11 when it's normally 100+. Upload was acting screwy as well, giving off the same behaviour. This all started happening after installing the connmon script. I should probably post all of this in the spdmerlin thread, but seeing as I suspect this script to be the culprit, I'll post here.
There's literally no overlap between the two. spdmerlin runs at 12 and 42, connmon runs every 5 mins. Neither script runs continously and only run when invoked by cron
What size swap file do you have? It would be worth watching htop for memory usage while spdmerlin runs a test
It might be worth doing an M&M config as per @L&LD's signature
1GB
Just did some testing on a new install of the script. Running a test directly from the script (option 1) outputs proper results. However hitting the button in the GUI outputs this in the logs:
Apr 19 17:42:27 spdMerlin: Speedtest results - Download: 0.00 Mbit/s - Upload: 0.04 Mbit/s
1GB
That timestamp is awfully close to the automated test - I wonder if it's trying to run concurrently
EDIT; but yes, please continue this in spdmerlin thread
Are you retired, jobless, won the lottery or did your wife leave you?
:D:D:D
right? Jack's one prolific mo...uh, person lately with all these script babies he's made and updates he fires off. someone call 9-1-1 because he's on Fiya, yo!
connmon and ntpmerlin could be somehow combined, no? both display jitter...
Jack Yaz is very prolific and produces great scripts!
I like that connmon and ntpMerlin are separate. They give a deeper understanding of the network, as a whole. Together, I think that depth may be lost. :)
Together they may give a broader overview picture of the network as a whole. A general survey, so to speak. Perhaps as a starting point to focus in and diagnose any issues.
I would think the combination of connmon and spdMerlin would be a better “Internet” status/health/performance check.
ntpMerlin (and it’s jitter) are more focused on real-time network time/services.
Speaking of network monitoring, is anyone using Nagios on their home network? I have compiled a working version of the NRPE plugin that runs on Asuswrt-Merlin.
When we have even laptop equivalent hardware to go inside our routers, I would agree with a connmon + spdMerlin merge. :)
Right now, that will not work for anyone with less than a top router (CPU + RAM) and no one with Gbps service. :(
