connmon connmon - Internet connection monitoring
I am not able to run startup scrip, it's not mounting asp file. What is going on?
mbok@RT-N18U-9F08:/www# bash -x connmon startup 2>&1 | grep mount
+ umount /www/AiMesh_Node_FirmwareUpgrade.asp
+ umount /www/AdaptiveQoS_ROG.asp
+ mount -o bind /jffs/scripts/connmon.d/connmonstats_www.asp /www/AiMesh_Node_FirmwareUpgrade.asp
mount: mounting /jffs/scripts/connmon.d/connmonstats_www.asp on /www/AiMesh_Node_FirmwareUpgrade.asp failed: No such file or directory
+ umount /www/require/modules/menuTree.js
+ mount -o bind /jffs/scripts/shared-jy/custom_menuTree.js /www/require/modules/menuTree.js
+ umount /www/start_apply.htm
+ mount -o bind /jffs/scripts/shared-jy/custom_start_apply.htm /www/start_apply.htm
An rt-n18u. Is that even supported by merlin?
No it's not :) Yet, it still should be working - other amtm scrips are working just fine.
/www/AiMesh_Node_FirmwareUpgrade.asp is only on specific routers?
Any tip so I can repair this myself? mounting this one file is not working.
EDIT: OK I've figured it out. You are using less common asp files, and replacing them by mount. If there is no such file, it can not be mount (my case).
You're running on an unsupported model *shrug*
im just curious about the performance impact of the scrip im should safely assume its not going to cause my any latency spikes during online games?
Also I can confirm it works on the RT-AX88U, but the run ping test doesn't work for some reason I had an error flag up about the rog page.
Not sure what is happening - but connmon is no longer showing me the correct page.
I tried a uf to see if that would resolve the issue - but still showing the wrong page.
Anyone else seeing this? Any thoughts as to how to remedy?
Try a complete uninstall (Z option) and reinstall.
Reinstall Entware I had the same issue, that's what fixed it for me, but I still get the rog page error.
this is the new layout. it pings administration feedback. every 5 minutes..... no not really try reinstalling using UF and then running a ping.
you shouldn't need to uninstall and reinstall you could just simply run
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/connmon/master/connmon.sh" -o "/jffs/scripts/connmon" && chmod 0755 /jffs/scripts/connmon && /jffs/scripts/connmon install
from the command line
v2.0.0 is now available!
Changelog:
Migrate from rrdtool to ChartJS
Nice!! Thanks for the update!! I like how it's interactive now so you can zoom in etc. Now can you do the same for spdMerlin? It would be awesome!! .
Also I have a question. By default. The speedtest runs every 12 minutes past the hour and 42 minutes past the hour. Any way I can change that?
Thanks!!!
Edit: oops sorry I asked the question for spdMerlin here. :O
Hi everyone,
I have a question, I installed connmon on my AC68U and I love the graphs: https://i.imgur.com/m3jfYTn.png
However, according to netdata installed on my router, connmon absolutely destroys my CPU every 5 minutes: https://i.imgur.com/qMuUYEV.png
Is there any way to reduce the massive CPU load on my router? Is this load "normal"? Could there be any issues caused by this massively increased CPU load on my router, such as increased latency, reduced download/upload speeds, etc or is this perfectly fine and normal? I would appreciate any and all information and opinions about this.
Hi everyone,
it's not hitting 100% usage, so i wouldn't use the word "destroy" please
Sorry, my mistake with the terminology - but, it's still hitting 93% so it's not like it's far off of 100%. That seems kind of excessive for me every 5 minutes. I see you're the author of this software, and I'm new to this software. Do you think you might be able to answer any of my questions about it?
