Voxel
Part of the Furniture
Right QOS v2.0 with DB/
I do not understand: if so why you do not use my previous build 1.0.2.30SF with previous QoS DB if it is OK for your needs?
Voxel.
Having spent 250 dollars in my country currency. I am felt i made a wrong choice . I thought this hardware is equal to R7000 interms of reliability and flexibility.
Somehow this dynamic QOS making me crazy.
Voxel.
Okay for a start the GUI is not going to respond as quickly as the actual QoS itself there is a GUI lag, so stop watching it. Its just there as a representation of what's happening really, the chipset is doing the work so much faster than the GUI shows. Also you have not figured in your network (ISP) You can have a a great router based QoS but if your provider shapes and throttles your connection which it may well do especially at peak times then there is nothing that really can be done, the router is doing its best with what it has. Leave the GUI, out of the equation, you have the SNB explanation of how streamboost works and that is that.
I have no buffering issues, but there is only myself in the house, my ISP (IDNet in the UK) does not shape throttle or block ports so in theory I should get no slowdowns when peak time usage starts, and I don't. My line runs as fast in the evening as in the day time. I can watch a 4k HDR stream and use my iPad quite happily or I can download a film to the sky Q box and game with no issues. Your usage may vary but where the router is placed, what frequency's you are using wirelessly for your devices (mine are mostly 802.11ac the printer is 802.11.g on 2.4Ghz) will all have an effect on your own network and the variables or your home, your neighbours routers and your ISP and its policy on traffic management and even the latency of your connection will all effect your final outcome.
Where did I miss this quote? "all traffic by default be routed over the tunnel"Sorry, but only: "all traffic by default be routed over the tunnel". NETGEAR has own firewall and GUI (prebuilt), and even minimal changes are problematic.
Voxel.
I swear I read your .docx file, and the change log in OP for this info before asking.
Question about the VPN client. Once an ovpn file has been set up with the appropriate keys, will all traffic by default be routed over the tunnel?
I just tried also, and it failed to register. I don't use this feature but you could always use your ip address wan side or use the Dynamic DNS Service
https://*********.mynetgear.com/shares:443 or different port # assigned in advanced settings
https://IP address/shares:443
There seems to be a problem with being able to "Register" with Readyshare USB devices on this current Voxel .31 version. During my testing, it also appears on the .28 version of the stock firmware. Downgrading to stock version .20 will allow a user to register a drive and allow the visibility of the drive in the Readycloud site. Has anyone else noticed this issue and can offer a more efficient work around?
Thank you
It means that my integration of a stock 1.0.2.28 was successful. Bugs in 1.0.2.28 are integrated too...
Well, IMO you have to report this bug to NETGEAR. I personally do not use this ReadyCLOUD, but some people like this feature.
Workaround is what deweyii suggested, right, or use of OpenVPN, when you can get an access to your local LAN. I prefer OpenVPN with mapping shared disks from my LAN (including attached to router) by samba to remote computer (over OpenVPN). Security.
Voxel.
Voxel.
You are right i did it and i updated in the v30 thread on my experience of 30F post 1 day still up and running. I cant demand more. But if you can and find time 31F without QOS v4DB would be great update for me without touching the Stream boost functionality.
macoui-db_20160607112939-cloud-gb8be08c-generic-1_all.ipk
p0f-db_20160607112934-cloud-gbaabd85-generic-1_all.ipk
policy-redis_20160607112945-cloud-g3bc8341-generic-1_all.ipk
wopr-db_20160607112951-cloud-g0e9656a-generic-1_all.ipk
/bin/opkg --force-downgrade install macoui-db_20160607112939-cloud-gb8be08c-generic-1_all.ipk
"Processor company": do you mean QCA? These packages are downloaded from the link used by NETGEAR firmware for QoS upgrade. IMO it is QCA development, but processed by NETGEAR. I do not know all details.Are these DB from Netgear or from Processor company directly. I believe it has to be from Netgear.
2nd you mean to say i upgrade to 31F and then downgrade the QOS to v2.0
I got it i need to flash to 31f and downgrade the QOS files and reboot will make it stable as before but with the 31F upgraded binaries
Welcome To SNBForums
