Custom firmware build for R7800 v. 1.0.2.73SF
Can you share the NG firmware download web/ftp site ?
Tia.
I don't have a link. I got notified by the firmware itself when I loged in. At the top was a banner saying new firmware was available. Went to the firmware settings and it reported .68 was available so I flashed it just to see what they broke this time
@Voxel
Is it possible to add device level bandwidth limiting to your custom firmware for the R7800?
is it possible? yes. will he do it? i doubt it. that's a major undertaking
Yes, it is rather problematic to implement such stuff. Such stuff are almost useless w/o GUI. I have very limited possibilities to make the changes in GUI (no source codes).
Voxel.
@Voxel
Do not use net-wall from stock .68 for your next release. See comment above
Rather impossible. No source codes even for stick 63. I deal with source codes.
https://kb.netgear.com/2649/NETGEAR-Open-Source-Code-for-Programmers-GPL
P.S.
As far as I know this new 68 is just an attempt to fix the issue with WAN port in AP mode. So IMO changes are exactly in firewall (net-wall). So no sense to process this. Agree with this:
:D - typical NETGEAR
If you remember 62 also had an issue with net-wall (Pi-Hole owners). So I've not used it even from 62. As usual: fixing bug and introducing few more...
P.P.S.
Thanks for your present. I've got notification from vladlenas.
Voxel.
Voxel.
Is it possible to hijack GUI elements to change their functionality?
Voxel - thank you very much for your outstanding work!
I originally wanted to wish you a Merry Christmass - but I think this should be in two weeks?
