so... what's the point of clicking the "restore factory default settings" in the GUI after clearing nvram?
has anyone checked the code no pun intended hggomes Im thinking about flashing rt-n18u is it ok for novice users?
I've already dl the firmware before the links were down
from what I understand hggomes hasnt released the source code yet..
NOTE: Make sure there's no hidden botnets on those after analising the entire code, good luck![]()
CURRENT VERSION:
*3.0.0.4_376.49_HGG-FINAL* (STABLE) - CHANGELOG
*3.0.0.4_378.50_HGG-ALPHA4* (ALPHA) - CHANGELOG
*Use this ALPHA version only for testing purposes*
Updated Packages:
bonnie coreutils curl cyassl diskdev_cmds dnsmasq dosfstools e2fsprogs ebtables ecmh flac flex gdb GeoIP iperf ipset iputils libexif libogg libpcap libupnp libvorbis libxml2 lighttpd (CVEs only) lsof lzo matrixssl mDNSResponder neon net-snmp netstat-nat ntfs-3g openlldp openpam openssl pcre pppoe-server pptp-client pptpd radvd sdparm sqlite strace tcpdump udhcpd udpxy vlan vsftpd (fix syslog warning msgs) wget wireless_tools xl2tpd xzutils zebra zlib
*unlocked* means you don't need to edit/flash CFE to have all channels and power levels available on the routers, these FW by itself allows you to.
RT-N18U:
FIRMWARE 376.49 (STABLE)
SHA256 CHECKSUM 376.49
FIRMWARE 378.50 (ALPHA)
SHA256 CHECKSUM 378.50
NVRAM SETTINGS
so did you try it?
100% = 80mW so you can set it up to 200% or 300% nothing will change it will be always 80mW.
| Thread starter | Title | Forum | Replies | Date |
[Custom Icons] ASUS Router App icon Completion Project - 180+ High-Quality icons | ASUS Wi-Fi | 3 | |
| U | Custom IPv6 DNS in Router Advertisements | ASUS Wi-Fi | 7 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
