CUSTOM/FORK RMERLIN FIRMWARE
hello,
I unfortunately do not have the knowledge to integrate pppoe-server on my rt-ac68u to replace my internet box.
Can you help me ?
Thx
You talked about RMerlin FW, so my answer was based on your words.
My fork is not available anymore, you can try this one:
http://forums.smallnetbuilder.com/showthread.php?t=18914
will your fork be available again any time soon or is this the end of it?
and just to add is it possible either way that you could post some info on how to edit the firmware to unlock it enabling us to change the TXpower
He said they will be backup when they are ready.
edit nvram
Need some help with Putty, using hggomes great fork look at this code.
nvram set wl_txpower=youchoose
nvram set wl0_txpower=youchoose
nvram set wl1_txpower=youchoose
looking at this code, the output using get command the answer is 100, would I replace the 100 to 150 and then commit those three lines. Thans for any help just tring to be carefull.
Regards
No, it will not work, maximum txpower is 100 = 80mW.
Thank you for quick reply, Im going by your thread that says
nvram set pci/2/1/ccode=#a
nvram set pci/1/1/ccode=#a
nvram set regulation_domain=#a
nvram set regulation_domain_5G=#a
nvram set pci/1/1/regrev=0
nvram set pci/2/1/regrev=0
nvram set wl_reg_mode=off
nvram set wl0_country_code=#a
nvram set wl0_country_rev=0
nvram set wl_country_code=#a
nvram set wl1_country_rev=0
nvram set wl_country_rev=0
nvram set wl1_country_code=#a
nvram commit
reboot
I saved all versions off your fork, before you removed them. What am i missing here sir..
Sam
nvram commit
reboot
Sam
Good
Could you please share the latest one with us ?
378.50 FINAL for N18U
Please share 3.0.0.4_378.50_HGG-FINAL firmware for RT-N18U model, even just in binary form (.trx).
Thanks.
just read the release notes and i must say the slider been able to actually change the powertx is awesome, cant wait until your firmware is back up to download.
Glad you haven't given up after all the hassle you got just wish you would put links backup sooner :):)
I would love to get 3.0.0.4_378.50_HGG-FINAL for RT-N66U.
I'm so annoyed, that those few f****ng moaners made this happen... I just don't get it, if they don't want to use it, why bitch so others can't use it either!
It was supposed to be a private message to the users asking for a link to the FW, it seems the smartphone was not that smart after loosing connection/back/forward it posted the info in here :)
Cheers
question
I was on .50 ta from merlin do I need to factory reset router and do I have to go into putty for the extra tx power? I saw in the readme that 25% is 200mv is that correct on the final version?
