I noticed after upgrading to 388.1 on my RT-AX88U, DDNS updates with namecheap no longer seem to be working. I noticed it when I happened to reboot my router the other day, the WAN IP changed but it was never updated. I verified if I manually update the IP address on namecheap my router is reachable again. I also verified I could successfully update the record using a standalone utility on my PC that namecheap provides, so I do not believe there is an issue on their end.
The router seems to think it could successfully register.
the logs reflect this too:
Feb 2 20:34:43 ddns: update WWW.NAMECHEAP.COM namecheap, wan_unit 0
Feb 2 20:34:43 disk_monitor: be idle
Feb 2 20:34:43 ddns: Clear ddns cache.
Feb 2 20:34:43 ddns: Start Inadyn(10).
Feb 2 20:34:43 inadyn[3171]: In-a-dyn version 2.9.1 -- Dynamic DNS update client.
Feb 2 20:34:43 inadyn[3171]: Update forced for alias xxx, new IP# xxx
Feb 2 20:34:43 inadyn[3171]: Updating cache for xxx
I already tried a factory reset on the router, and the issue has occurred again since doing that, so seems to be a more persistent problem.
Is this a known issue? I searched the forum but did not see any reports of this on the latest firmware.
