WDTV Live Plus with homebrew firmware
This firmware is awesome. I'm getting HULU, Netflix and Mediafly so far. These guys are awesome.
http://b-rad.cc/1295/wdlxtv-plus-for-wdtv-live-plus/#more-1295
http://b-rad.geg0r.de/index.php?dir=
http://wiki.wdlxtv.com/Main_Page
WDLXTV-Live is an unofficial homebrew firmware for the Western Digital WD TV Live. It enables a wide range of extra functionality which is missing from the official firmware, such as bittorrent, webserver, NZB, SSH, FTP, etc. I’ve done my best to make everything as easily configurable as possible, but it does require a little bit of work on your own. All of the settings are located in S00custom-options, which is included in the zipfile of every release. Open it in a text editor and peruse your options. If you need help there is a forum link at the bottom of the page. If you are a power user then you’ll be able to harness your Linux skills and fly off into the world of homebrew, wondering why you delayed any longer than you did.
This version has about as many changes as you can possibly make in one firmware. Things might have been a bit silent for the last few months, but in reality this firmware has been under constant development changing everything under the hood. Big thanks to recliq, who has stepped up to help with programming & maintenance.
0.4.2.1
* pibos WDTVExt dynamic extension software integrated
* thespecialist's WMAPro audio support
* psychodad's autoframerate/resolution patch
* recliq's moviesheet plugin
* recliq's WDTVExt plugin manager
* AutoZoom overscan fix during video playback
* forcehdmi option for resolutions not contained in EDID
* Samba/smb.conf fixes for missing/nonworking network shares
* Zosters's UMSP-0.14 with searching capability
* OK button comes before cancel in network share login & resume message boxes
* UMSP plugins are pulled from svn on boot, enable them individually through webend
* multi-file custom UMSP plugins enabled (/conf/umsp.php + /conf/umsp-plugins.tgz)
* fixed peristent video resume points file on local device; video_resume_point_table
* Setting for password protected Samba shares with guest read only access
* Samba debug level can be set
* fixed /boot with .rootFS
* webend symlink permission fixes
* youtubeHD fix
* rtorrent-0.8.6-1 included
* rutorrent-3.0 included
* ffmpeg-SVN-r22988 included
* curl_7.20.0-3 included
* new user supplied init.d script now avaiable: /conf/S99user-script
* sorted path/plugin errors (mostly) in rutorrent
* linksheets disabled, recliq's WDTVExt movisheet plugin enabled
* Python removed
* Deluge removed
* fixed load.webplugin bug causing rogue setup links in webend
* included mediainfo-0.7.25
* included apache2
* ability to set custom telnet/ssh ports
* /dev/sda1 is now fsck'd if root.bin/.rootFS exists at boot
* included tcpdump-3.9.8
* fixed domain wide auth
* updated osd pages to wdlxtv.com
* jamiroo's corrected spanish localization
* Techflaws.org's corrected german localization
* avkiev's corrected russian localization
* jamiroo's catalan localization
* Staduk's Greek localization
* bagira's Hungarian localization
* ReMARKable's dutch localization
* moved deluge/nzbget/umsp/webend web dirs to /usr/share
* lots of extra logging in scripts for bug report in webend
* mount.watch rewritten - usb hubbed devices now mounted under the slot they're plugged into (media library = off)
* tons & tons of bug patches & minor enhancements/tweaks
Is that enough for one update?
