Kariphoenix
The issue persist with pixelserv disabled as well.
If you are not already using DNSFilter, try enabling it and ensure the Global Mode is set to router, thereby making sure the PC is using the same DNS server as your other devices as well as using Skynet and Diversion.I cannot open https://www.chuyu.me/ on my PC.
I know how to resolve/whitelist a domain in diversion and skynet.
I can open this page on my mobile phone, when I disconnect from my wlan.
I also can open this page when I connect my PC to my mobile phone hotspot.
I just cannot open this page when I'm connected to my wlan.
I already temporarily disabled diversion and skynet, still I cannot open this page.
Strangely I can ping www.chuyu.me, and it says "Antwort von 47.246.47.208: Bytes=32 Zeit=58ms TTL=53"
I don't use a proxy.
My router is 192.168.1.1 and this is in syslog:
Jul 28 22:24:33 dnsmasq[2804]: using nameserver 8.8.4.4#53
Jul 28 22:24:33 dnsmasq[2804]: using nameserver 8.8.8.8#53
So this problem is not related to diversion, skynet or my browser.
Any suggestions?
Edit:
I now tried to set DNS 1.1.1.1 manually in my router, now I can reach the website, but another website still doesn't open: https://www.dnsperf.com/
Where do I find "DNSFilter"?If you are not already using DNSFilter, try enabling it and ensure the Global Mode is set to router, thereby making sure the PC is using the same DNS server as your other devices as well as using Skynet and Diversion.
That site opens for me (redirecting to https://www.chuyu.me/en/index.html). I use Skynet and Diversion, default blocking lists (and DNSFilter, Global Mode Router).
You list all the exceptions to the Global Mode in the Filter Mode boxes at the bottom of the page. And if the DNS server you want is in the list eg OpenDNS, you select that, otherwise you have up to 3 custom choices. (In my case, I simply use Router for Global and no exceptions.)Where do I find "DNSFilter"?
Edit:
Ah, found it.
Gonna play around a bit.
Edit2:
Do I have to manually add clients to the clients list in DNSFilter or are all clients automatically using the custom DNSs?
Can you tell me what you're trying to open when you get the "oops" error message? I can try to mirror what you're doing to see if i get the same error message.
I gave up a long time ago on using the amazon android app at home.Any luck reproducing this issue with the Amazon Shopping app on Android? Appears to be 100% reproducible on my end so I am still keeping pixelserv-tls disabled.
Have you tried rebooting the router?
Maybe, twice?
And waiting a good ten minutes after it boots up before testing if it works?
Maybe, twice?
No ads on macrumors for me
Maybe, twice?
Might be time to update some things too....AMTM has been updated to 2.7 now.Okay, I figured out what was causing this.
I setup a new Openvpn Profile (Expressvpn) and for some reason it just wouldn't work. All the settings were correct to allow diversion to work, Ive done this a million times over.
So the solution to making the VPN connection to work was to add DNS addresses to LAN>DHCP Server>DNS and WINS Server Setting>DNS 1 and DNS 2. This stopped Diversion from working it appears.
So to get the VPN connection to work, and get Diversion working I went to LAN>DNSFilter>Enable DNS-based Filtering to ON > Global Filter Mode set to Router.
Now the VPN is working and Diversion is working. No more Ads.
Thanks for letting me knowMight be time to update some things too....AMTM has been updated to 2.7 now.![]()
I went from 2.1 to 2.7 has amtm really been updated that much in the last 3 to 4 months? I've been regularly checking for updates for Skynet and Diversion but forgot all about amtm.
Sent from my iPhone using Tapatalk Pro
Just like Skeptical.me, I have lost most if not all ad blocking in the past few weeks. I have tried Skeptical.me's suggestion of turning on "Enable DNS-Based Filtering", but that didn't do anything. I am using the default 9 lists. When most things were working, if I looked at the default "New Tab" on the edge browser every box that was labeled "Ad" in green had the picture removed and did not go anywhere. Now every one of them has a picture and if you click on it you go to the AD site. I have updated diversion to 4.1.3, and amtm to 2.7, so I think I am up to date.
Welcome To SNBForums
