Hello
I will install DIVERSION but i have a question. When i want install DIVERSION with the pixelserv-tls then i have this message.
Currently is on my router IP
pool start address = 192.168.99.2
pool end address = 192.168.99.254
If i now set the range according to the instructions of 192.168.99.2 - 192.168.99.3, how then get my other devices their IP number, if the range contains only 2 numbers? I don't understand that.
Thank you very much.
Go to LAN > DHCP Server
- Adjust "IP Pool Starting Address" from the
standard xxx.xxx.xxx.2 (typically 192.168.1.2)
to xxx.xxx.xxx.3 (e.g 192.168.1.3)
(xxx.2 would be the reserved address)
- Make sure the reserved address is not used
by your other devices
- Then click "Apply"
