Diversion Diversion - the Router Ad-Blocker
I'm assuming you installed the cert on the Win and Linux boxes as well?
Yes Cert is installed on all devices.
Try disabling DNSSEC strict validation as a test. You have some Insecure responses on your log.
These 3 are currently set to yes
Enable DNS Rebind protection
Enable DNSSEC support
Validate unsigned DNSSEC replies
DNS-over-TLS Profile is set to strict will change this one.
I had to turn off rebind protection. It broke dozens of commercial websites for me.
Keep it set to strict. Change one variable at a time, but I bet it's rebind.
So far none has worked.
I first set it to DNS over-TLS to Opportunistic didn't work.
Then tried taking off DNS Rebind Protection also didn't work.
The log file doesn't show anything in the blocked domains for twitch so all very strange.
This use to work fine then all of a sudden cannot connect. Twitch on a browser works fine.
As I follow the log of blocked domain when I open the twitch app I see these
19:17:43 blocked by blockinglist www.googletagservices.com
 19:17:44 blocked by blockinglist ssl.google-analytics.com
 19:17:44 blocked by blockinglist sb.scorecardresearch.com
 19:17:44 blocked by blockinglist cdn-gl.imrworldwide.com
 19:17:44 blocked by blockinglist s.amazon-adsystem.com
*update*
So I went from standard + to standard still no go.
When I went to the small Blocking list everything works fine now.
So there is something in Standard + & Standard blocking list that is causing the issue.
*update*
Maybe you can try and see which one of those is not blocked when you are on 'small blacklist' and then whitelist the domain when you switch to standard . Could be a 'middle' domain which causes this issue
Hello:)
What exactly do I have to do so that domains are always blocked with and without www.? Both domain options must be on the lock list or not?
Thanks.
Guys, please help me to understand what is going on. I use DNS from AdGuard via DoT and sometimes get an NXDOMAIN error. After 1-2 minutes, the site loads normally. There are no errors in the log through stubby -l, but in the log dnsmasq at the time of the error I see such lines:
Aug 15 18:27:53 dnsmasq[989]: query[A] accounts.epicgames.com from 192.168.1.3
Aug 15 18:27:53 dnsmasq[989]: forwarded accounts.epicgames.com to 127.0.1.1
Aug 15 18:27:53 dnsmasq[989]: dnssec-query[DS] amazonaws.com to 127.0.1.1
Aug 15 18:27:53 dnsmasq[989]: Insecure DS reply received for com, could be bad domain configuration or lack of DNSSEC support from upstream DNS servers
Aug 15 18:27:53 dnsmasq[989]: reply amazonaws.com is BOGUS DS
Aug 15 18:27:53 dnsmasq[989]: validation accounts.epicgames.com is BOGUS
Aug 15 18:27:53 dnsmasq[989]: reply accounts.epicgames.com is <CNAME>
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 52.202.243.46
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 35.168.66.53
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 35.171.206.70
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.205.226.14
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.230.100.209
Aug 15 18:27:53 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.203.152.178
Aug 15 18:27:58 dnsmasq[989]: query[A] accounts.epicgames.com from 192.168.1.3
Aug 15 18:27:58 dnsmasq[989]: forwarded accounts.epicgames.com to 127.0.1.1
Aug 15 18:27:58 dnsmasq[989]: dnssec-query[DS] amazonaws.com to 127.0.1.1
Aug 15 18:27:58 dnsmasq[989]: Insecure DS reply received for com, could be bad domain configuration or lack of DNSSEC support from upstream DNS servers
Aug 15 18:27:58 dnsmasq[989]: reply amazonaws.com is BOGUS DS
Aug 15 18:27:58 dnsmasq[989]: validation accounts.epicgames.com is BOGUS
Aug 15 18:27:58 dnsmasq[989]: reply accounts.epicgames.com is <CNAME>
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 35.168.66.53
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 35.171.206.70
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.205.226.14
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.230.100.209
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 34.203.152.178
Aug 15 18:27:58 dnsmasq[989]: reply accountportal-website-prod07-epc-739724359.us-east-1.elb.amazonaws.com is 52.202.243.46
Whether it is possible that DNSSEC incorrectly works on these servers? I have these options in the WAN tab for DNSSEC:
Enable DNSSEC support - YES
Validate unsigned DNSSEC replies - YES
Enable DNS Rebind protection - YES
Thanks.
Hello
I have slow loading times on websites like bild.de and i think it‘s purhaps something wrong with Diversion. Is this possible or what i can do for better/faster loading times?
Thank you
I had the exact same problem with a lot of sites that I visit regularly. They would all load excruciatingly slow - several minutes or more each. I was using the Medium blocking list. I finally changed to the Standard blocking list and the problem went away. Not particularly happy about having to use a much smaller list of blocked sites, but it was the only acceptable option for me. I couldn't tolerate the huge performance hit with the Medium blocking list. Better to block fewer sites than none at all...
Thanks.
Why use Adguard DNS upstream? You can just import their blocklist if you really want (it's on GitHub) and use a more reliable upstream provider (Quad9, Cloudflare).
@HawkInOz My problem is that the page loads slowly, but when i make a reload in the browser (Chrome, Safari, Firefox), the page is immediately there. I have already checked whether any domains are blocked, but in the log i see nothing. Is actually synonymous logical as i said, with the reload the page is displayed yes. I don't know what's the problem!
Of course I know that. But this is a very different question...Now I need to figure out why this errors occurs:)
Hello
What can i do when Diversion not open? I'm in the amtm and choice 1 but Divison will not open, no error on the screen.
Thank you
hello,
quick question, I'm getting the following error while trying to run pixel service:
/opt/bin/diversion: /opt/share/diversion/file/functions.div line 1776 syntax error unexpected ";;" (expecting "then")
syslog
Aug 15 19:30:26 kernel: pixelserv-tls[7848]: unhandled level 0 translation fault (11) at 0x47bf3e0dd00, esr 0x92000004
Aug 15 19:30:26 kernel: pgd = ffffffc011a5d000
Aug 15 19:30:26 kernel: [47bf3e0dd00] *pgd=0000000000000000, *pud=0000000000000000
Aug 15 19:30:26 kernel: CPU: 0 PID: 7848 Comm: pixelserv-tls Tainted: P           O    4.1.27 #2
Aug 15 19:30:26 kernel: Hardware name: Broadcom-v8A (DT)
Aug 15 19:30:26 kernel: task: ffffffc01393eb40 ti: ffffffc00a78c000 task.ti: ffffffc00a78c000
Aug 15 19:30:27 kernel: PC is at 0x7f8cdeae80
Aug 15 19:30:27 kernel: LR is at 0x7f8cdeb574
Aug 15 19:30:27 kernel: pc : [<0000007f8cdeae80>] lr : [<0000007f8cdeb574>] pstate: 80000000
Aug 15 19:30:27 kernel: sp : 0000007fc6ccba60
Aug 15 19:30:27 kernel: x29: 0000007fc6ccba60 x28: 0000007f8ce09000
Aug 15 19:30:27 kernel: x27: 0000007f8ce08000 x26: 0000007fc6ccc370
Aug 15 19:30:27 kernel: x25: 0000007f8cdf4000 x24: 0000000000000001
Aug 15 19:30:27 kernel: x23: 0000007fc6ccbc00 x22: 0000000000000000
Aug 15 19:30:27 kernel: x21: 0000007f8ce02ca0 x20: 0000000000000010
Aug 15 19:30:27 kernel: x19: 0000007f8ce033a0 x18: 0000000000000001
Aug 15 19:30:27 kernel: x17: 0000007fc6ccc4b8 x16: 0000000000554e47
Aug 15 19:30:27 kernel: x15: 0000007f8ce0a700 x14: 0000000000000000
Aug 15 19:30:27 kernel: x13: 0000007f8ce09008 x12: 0000000000000040
Aug 15 19:30:27 kernel: x11: 0000000000000001 x10: 0000000000000010
Aug 15 19:30:27 kernel: x9 : 0000000000000000 x8 : 0000007f8ce028b8
Aug 15 19:30:27 kernel: x7 : 0000000000000000 x6 : 0000000000000000
Aug 15 19:30:27 kernel: x5 : 0000000000000004 x4 : 0000007f8ce033b0
Aug 15 19:30:27 kernel: x3 : 0000007f8ce03340 x2 : fffffffffffffff0
Aug 15 19:30:27 kernel: x1 : 0000007f8cdfb3a0 x0 : 0000007f8ce033a0
anyone got some advice?
Hello
Thank you
Do you have all the requirements met?
Until yesterday, everything worked fine and today i have a router reboot and now nothings works. X3mRouting opens without problems.
EDIT: When i make a update check on AMTM, then is behind Diversion "upd err"
Login to your router admin page, and go to System Log > General Log. Under "System Time", is the time set correctly?
