Unfortunately this didn't help, it is not the domain itself, I think it uses some Google services to deal with the property pictures.You can add this domain to your diversion whitelist.
The problem is b.dmlimg.com as can be seen from your dnsmasq.logUnfortunately this didn't help, it is not the domain itself, I think it uses some Google services to deal with the property pictures.
/opt/share/diversion/list/blockinglist b.dmlimg.com is 192.168.50.2
Why it made the block list I do not know, so I do not know the risk involved in whitelisting it.Code:/opt/share/diversion/list/blockinglist b.dmlimg.com is 192.168.50.2
Is it just me, or the ads continue to show? all of them?
Mostly on android apps that have ads...
Disabled...Did you enable Android's Private DNS? That would cause you to completely bypass Diversion.
You just have to ensure the devices use the router IP as the DNS server. No other DNS servers provided by LAN DHCP Server and no DNSFilter mode besides Router (or disabled).Just to clarify, after install and configure Diversion, I just have to simply surf the web, correct? Or do I have to make any special configuration on my terminals (mobile phones, PC, etc..)
It’s OK as long as all your clients on LAN use the router as DNS. DNS Filter can be enabled with Router mode to force all clients on the LAN to go through router DNS (and also Diversion). This would be in case they try to override the DNS settings or have hardcoded DNS servers (e.g, Google devices).I have router DNS Filter disabled... Is it correct?
And if i activate DNS Filter and don't add any client to list, will it force ALL clients? Or i have to manually add all clients on my network to DNS Filter list?It’s OK as long as all your clients on LAN use the router as DNS. DNS Filter can be enabled with Router mode to force all clients on the LAN to go through router DNS (and also Diversion). This would be in case they try to override the DNS settings or have hardcoded DNS servers (e.g, Google devices).
All clients will default to the Global mode. If you need to make an exception for one or more clients (e.g. No Filtering, OpenDNS, etc.) then you would add a client in the client list.And if i activate DNS Filter and don't add any client to list, will it force ALL clients? Or i have to manually add all clients on my network to DNS Filter list?
Since I've installed Diversion and Skynet, I have noticed very little negative (erroneous) impact on my website viewing, with one exception: the Montreal Gazette's website. While not totally crippled, it's getting close. I don't want to play with Whitelists and such without knowing what I'm doing. Does anyone know why this website is being negatively (I assume) impacted by Diversion or Skynet?
https://montrealgazette.com/
Anton
They rely on ad revenue.Hi,
Anton
Welcome To SNBForums
