Diversion Diversion - the Router Ad-Blocker
When YT blocking enabled
May  9 15:04:21 RT-AC5300-0680 Diversion: restarted Dnsmasq to apply settings
May  9 15:04:23 RT-AC5300-0680 Diversion: created br0:pixelserv-tls for 192.168.2.2
May  9 15:07:39 RT-AC5300-0680 Diversion: restarted Dnsmasq to apply settings
May  9 15:08:02 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:09:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:10:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:11:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:12:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:13:01 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:14:01 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:15:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:16:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:17:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:18:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:19:01 RT-AC5300-0680 Diversion: no YouTube temp file found
  • Like
Reactions: a5m
Enter this in the terminal, it should output a bunch of googlevideo domains:
/opt/bin/grep -ae "reply.*-.*\.googlevideo.*\..*\..*\..*" /opt/var/log/dnsmasq.log
Thanks LC working fine !!
That command did not magically make that happen. It just shows there are yt domains found.
I see not why that file is not created if your output actually contained domains. Did it?
joescian@RT-AC5300-0680:/tmp/home/root# /opt/bin/grep -ae "reply.*-.*\.googlevideo.*\..*\..*\..*" /opt/var/log/dnsmasq.log
May  8 15:42:56 dnsmasq[25574]: reply r1.sn-xmxuxa-ntql.googlevideo.com is 220.233.204.108
May  8 15:42:57 dnsmasq[25574]: reply r4.sn-ntq7yner.googlevideo.com is 173.194.28.73
May  8 15:43:11 dnsmasq[25574]: reply r2.sn-xmxuxa-ntql.googlevideo.com is 220.233.204.109
May  8 15:43:12 dnsmasq[25574]: reply r3.sn-ntqe6n76.googlevideo.com is 173.194.28.8
May  9 14:49:55 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:51:29 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:52:30 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:53:07 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:53:34 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:54:39 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:55:40 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:56:44 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:57:38 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:57:59 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:59:03 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 14:59:35 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:00:06 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:01:19 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:02:29 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:03:38 dnsmasq[19851]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:04:42 dnsmasq[31370]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:05:46 dnsmasq[31370]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:06:49 dnsmasq[31370]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:07:42 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:07:58 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:09:02 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:09:35 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:09:50 dnsmasq[4513]: reply r1.sn-xmxuxa-ntql.googlevideo.com is 220.233.204.108
May  9 15:09:51 dnsmasq[4513]: reply r3.sn-ntqe6n7r.googlevideo.com is 74.125.109.8
May  9 15:10:06 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:10:29 dnsmasq[4513]: reply r4.sn-xmxuxa-ntqe.googlevideo.com is 220.233.196.207
May  9 15:10:29 dnsmasq[4513]: reply r4.sn-ntqe6nes.googlevideo.com is 74.125.152.9
May  9 15:10:40 dnsmasq[4513]: reply r2.sn-xmxuxa-ntql.googlevideo.com is 220.233.204.109
May  9 15:11:09 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:12:14 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:13:32 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:14:38 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:15:41 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:16:45 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:18:03 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:18:31 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:19:04 dnsmasq[4513]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
They are all there but opt/share/diversion/list/yt_blacklist dosent contain anything - its 0 bytes - is this correct?
Havent encountered any YT ads on my tv fire stick :)
Good to hear. I'm still tweaking some parameters as my iPads and browsers occasionally do.
This is still a work in progress. I silently pushed an update hours ago to fix that damn double count when IPv6 is enabled.
But for further tweaks I'll let you all know when I do.
No. Is 173.194.28.9 the IP shown in b, 8?
NO
 This manages YouTube video ad-blocking
 googlevideo domains in yt_blacklist: 0
 The forced YT video IP is: 220.233.204.108
220.233.204.108
 1. Disable YouTube video ad-blocking
 2. Recheck YouTube video IP(s)
May  9 15:52:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:53:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:54:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:55:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:56:01 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:57:01 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:58:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 15:59:00 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 16:00:01 RT-AC5300-0680 Diversion: no YouTube temp file found
May  9 16:01:01 RT-AC5300-0680 Diversion: no YouTube temp file found
NO
220.233.204.108
Is IPv6 enabled? There should be only one IPv4 and if so an IPv6 address.
Run this for me in the terminal:
/opt/bin/dig r4.sn-ntqe6n76.googlevideo.com A +short
In what way could Diversion make YouTube better for us when we aren't home?
Setup an OpenVPN server on your router, and always connect to it from your mobile devices, that way you can benefit from Diversion "anywhere".
I hope you bake in an ipv6 aware version for the host file as well, or the youtube ad redirect will only work part of the time for those who run the ipv6. (basically for every ipv4 repeat the same entries for ipv6).
It is. And the IP's ought to be respective.
NO IPV6 enabled
joescian@RT-AC5300-0680:/tmp/home/root# /opt/bin/dig r4.sn-ntqe6n76.googlevideo.com A +short
173.194.28.9
NO IPV6 enabled
173.194.28.9
Run that option: 2. Recheck YouTube video IP(s)
 Done  YouTube IP(s) are unchanged
220.233.204.108
May  9 15:51:11 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:52:14 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:52:30 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:53:18 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:54:20 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:55:04 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:55:29 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:56:29 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:56:44 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:57:48 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:57:54 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:58:52 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:59:08 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 15:59:56 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:01:01 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:02:04 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:03:06 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:04:09 dnsmasq[1704]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:05:23 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:06:26 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:07:30 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:09:00 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:09:16 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:10:08 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:11:11 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:12:14 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
May  9 16:12:57 dnsmasq[13903]: reply r4.sn-ntqe6n76.googlevideo.com is 173.194.28.9
This is what many do, including me.
220.233.204.108
What browser are you watching youtube videos from. Also are you using any custom dns settings in these browsers which might be diverting you away from using diversion?
