Diversion Diversion - the Router Ad-Blocker
Could someone explain the use of pixelserv-tls?
It's enabled, but not sure what it does.
This is to import a CA for the web UI, is this the routers web UI? Or some other UI that may be useful?
Edited: Here's some lite reading for you.... majority of people I read disabled it. ;)
Here's some lite reading for you....Also I believe most have disabled it.
Ah, thanks for the links.
So, blocking ads served from HTTPS, and replacing the ad with a pixel. This sounds useful, even though I still get massive wasted space on pages. But makes sense for HTTPS served ads.
What's the reason for disabling it?
I couldn't exactly remember but I believe it was most people found it was causing more issues blocking items than helping. It hasn't been updated either if I recall. I had it enabled myself at one time but after disabling it I found no issue to turn it back on. Here is an explanation from @thelonelycoder on what happens when you disable it.
Excellent, thanks for your help.
Sorry, if this was already answered but is there a way to block specific device from connecting to host?
I would like block Amazon and other IoT devices from pinging to google all the time.
I really love what you are doing! Thank you!
I've watched the logs briefly and seen that the analytical, useless-for-the-end-user, stuff is being blocked by Diversion.
You need to look into Skynet not Diversion.
"Most people disable it" no I disagree. Although we would need a poll to collect data ;)
I continue to use it and manually take care of things so that my phone apps like Amazon shopping etc are unaffected by pixelserv.
I can reword it to "majority of people I read disabled it". ;)
Ah, I thought Diversion was doing this.
Something else I need to take a closer look at.
pixelserv-tls 2.3.1 (compiled: Mar 23 2020 07:23:17 flags: tfo tls1_3)
More recently updated than some scripts IMO!
Please excuse me, but a quick one off topic: Does anyone know why the PWR command would not be working from my SSH prompt?
kvic briefly re-appeared to merge my efforts to fix it up to make it fit for purpose with requirements forced by iOS/macOS changes, but it seems like the project is abandoned. i have removed pixelserv from my setup
Although it may be abandoned, it's still working fine for me. (with the caveat that for certain mobile apps like Amazon Shopping; you may need to employ some manual workarounds because they don't like pixelserv-TLS for some reason - pretty much everything else is fine)
Keep in mind that although FreshJR-QoS was abandoned in June (?) of 2019, we all continued to use it without major issues until FW 384.18 came out, which is the only point that we really needed to update to the newer FlexQoS due to Adaptive QoS changes in the base Asus firmware.
Not quite sure how to get this right. I've tried several combinations and still doesn't seem to work properly.
LAN/DHCP Server Page
DNS Server 1 and 2 are blank (which should default to RTAC68U address)
- I've also tried manually entering the IP address here
WAN Internet Connection
DNS Server 1 and DNS Server 2 are assigned 1.1.1.1/9.9.9.9 (though I tried setting this to blank and the RTAC68U IP)
Connect to DNS Server Automatically is No
DNS Privacy Protocol Set to DNS Over TLS
It's my understanding that given what's set in LAN/DHCP Server Page and WAN Internet Connection, that clients connected to the network should get RTAC68U address assigned as DNS server, and RTAC68U would then filter results poll DNS Servers established under WAN Internet Connection for IP addresses. What am I missing?
Can anyone help?
Quick post regarding pixelserv-tls,
Disabled it yesterday, and ads on my mobile phone were replaced with messy long URLs.
Enabled pixelserv-tls, no messy long URLs.
Just setting up email config, what is meant by SSL Flag?
@elorimer explained it better than I ever could:
I think it is actually something a little different. I think it works like this. Whether it is encrypted or not is a function of the protocol. So Gmail's smtp server uses smtps protocol, and the exchange of information sets up TLS encryption at the 256 bit level. The configuration dialog helpfully shows you the settings for four SMTP servers. But by default curl will attempt to verify identities, so Gmail's smtp server will want to see your humble little router verified in its CA chain. Which of course, it won't. The SSL flag allows you to specify the "--insecure" command, which tells Gmail's smtp server not to do that. If you go ahead, the connection is still encrypted.
Now, as a matter of safety, your gmail account is going to have 2FA in place. (If not, stop here.) When this is the case, the Gmail server is going to want to see the connection is verified by 2FA, which of course it can't. But the server also checks to see if you have a application-specific password in place, and if that password matches, the gmail server will accept the traffic.
As an aside, I think that field allows you to specify a bunch of curl options if necessary. Haven't come across the necessity for this.
