Diversion Diversion - the Router Ad-Blocker
Strangely I never see any ad on the Forum. I thought that SNBForum Ad domains were whitelisted. Any idea? I have not added/modified anything in addition to the standard install.
I do sometimes see the amazon link but nothing more than that.
I'm in contact with @thiggins to get an updated list of domains.
"Most people disable it" no I disagree. Although we would need a poll to collect data ;)
I continue to use it and manually take care of things so that my phone apps like Amazon shopping etc are unaffected by pixelserv.
So do I, pixelserv-tls runs on my main router and in most cases also on the various test routers.
pixelserv-tls still is a smartly coded piece of software that continues to work very well - if used and setup correctly. There's no denying that.
I lament the total absence and lack of communication and interaction with it's coder. This situation is not tolerable for me and I will eventually have to make a decision how to deal with it.
Please excuse me, but a quick one off topic: Does anyone know why the PWR command would not be working from my SSH prompt?
The firmware you are using likely does not come with the pwr binary, see what that gives, it should return /bin/pwr:
Bash:
which pwr
Bash:
which pwr
Thanks. That command simply returns you to the same command prompt.
Although it may be abandoned, it's still working fine for me. (with the caveat that for certain mobile apps like Amazon Shopping; you may need to employ some manual workarounds because they don't like pixelserv-TLS for some reason - pretty much everything else is fine)
Keep in mind that although FreshJR-QoS was abandoned in June (?) of 2019, we all continued to use it without major issues until FW 384.18 came out, which is the only point that we really needed to update to the newer FlexQoS due to Adaptive QoS changes in the base Asus firmware.
I stopped using after the manual workaround for the Amazon app stopped working. I tried everything! Haven't used it since and no issues and the fam is no longer nagging at me about the Amazon app. Glad is still working for you though!
Can anyone help?
Seems like a cry of desperation :rolleyes:.
WAN Internet Connection
DNS Server 1 and DNS Server 2 are assigned 1.1.1.1/9.9.9.9 (though I tried setting this to blank and the RTAC68U IP)
Connect to DNS Server Automatically is No
DNS Privacy Protocol Set to DNS Over TLS
I have: Connect to DNS Server Automatically is Yes and also DNS filter "on", mode "router" under LAN|DNS Filter.
Just wanted you all to know that I am constantly coding on the full Diversion WebUI when time and mood allows. It's going to be adequate, agreeable to the eyes and feature complete. A fair amount of work went into it and this continues until it's ready for release. As always, no ETA yet.
Great news, can't wait to use it! :)
I think the problem ends up being that SNBForums.com is using all the big names in advertising: Amazon, Google, Doubleclick, etc. To whitelist all of these to the point you actually see an ad on snbforum.com is going to affect ad-blocking on most of the major web properties. As an experiment, I’ve temporarily disabled Diversion and whitelisted snbforums.com in my browser adblocker. I had given up manual whitelisting after about 6 or 7 widespread domains.
I thought you were on vacation. But then, it could be a similarily spirited hacker like you that hacked your credentials.
Thanks for the efforts anyway, whoever you are. Tim and I came to the same conclusion.
COVID-19 vacations don’t last as long as old-fashioned vacations. And American vacations are considerably shorter than European vacations, in my experience.
My experiences confirm your experience.
  • Like
Reactions: a5m
Recently I keep getting the error "something went wrong at our end" when using Amazon shopping app. Going by what I've read the problem is being caused by Division blocking something.
Is there anyway to fix this problem?
