pattiri
4 of 13 hostsfiles? How big is your blocking file?
lol. it's 32 MB; 990,466 blocked domains 13 hosts file(s) in use
Can you post the content of the config file? Use sf.I nuked my router today and reinstalling everything. For some reason I cannot turn on stats for diversion. I tried to get into the logging feature by pressing l but it says the following,
Any help on how can I enable the stats?
Thanks.
/opt/share/diversion/.conf/diversion.conf has this content:
START FILE, --- lines are not part of file
## DO NOT EDIT THIS FILE ##
# General settings #
NAME=Diversion
thisVERSION=4.0
thisM_VERSION=2
EDITION=Standard
THEME=blue_on_white
INSTALL_URL=https://diversion.ch/diversion
DIVERSION_STATUS=enabled
adblocking=on
logging=
editorColor=
editorPaginate=
shHistory=on
# Communication settings #
divUpdate=on
weeklyStats=on
wsTo="email"
wsAs="body"
wsDo="delete"
wsTopHosts=10
wsTopClients=10
wsFilterLN=off
backup=on
buFrequency=weekly
buType="Key-files"
buAs=compressed
buCompression=tar.gz
# Blocking file settings #
bfType=Standard
bfPlusHosts=on
bfUpdateDay=Sunday
bfUpdateDOW=Sun
bfUpdateHour=2
bfUpdateLastRun="Oct 07 21:31:36"
bfUpdatePrevRun=""
blockingIP="192.168.2.2"
# Entware settings #
entPath="/mnt/pdas001/entware"
entVersion="Entware (armv7sf-k2.6)"
psState=on
prevPsState=on
psIP="192.168.2.2"
# Ad-blocking counters #
blockedDomains=840680
adsBlocked=0
adsWeek=0
adsNew=0
adsPrevCount=""
adsLastCount=""
# Dnsmasq settings #
dsSetting=on
logAsync=
cacheSize=
bogusPriv=
domainNeeded=
loqQueriesExtra=
# Messaging #
END FILE
I have uploaded a hotfix for your case. Use 33 to download the main script and then run l again.Code:/opt/share/diversion/.conf/diversion.conf has this content: START FILE, --- lines are not part of file --------------------------------------------------- ## DO NOT EDIT THIS FILE ## # General settings # NAME=Diversion thisVERSION=4.0 thisM_VERSION=2 EDITION=Standard THEME=blue_on_white INSTALL_URL=https://diversion.ch/diversion DIVERSION_STATUS=enabled adblocking=on logging= editorColor= editorPaginate= shHistory=on # Communication settings # divUpdate=on weeklyStats=on wsTo="email" wsAs="body" wsDo="delete" wsTopHosts=10 wsTopClients=10 wsFilterLN=off backup=on buFrequency=weekly buType="Key-files" buAs=compressed buCompression=tar.gz # Blocking file settings # bfType=Standard bfPlusHosts=on bfUpdateDay=Sunday bfUpdateDOW=Sun bfUpdateHour=2 bfUpdateLastRun="Oct 07 21:31:36" bfUpdatePrevRun="" blockingIP="192.168.2.2" # Entware settings # entPath="/mnt/pdas001/entware" entVersion="Entware (armv7sf-k2.6)" psState=on prevPsState=on psIP="192.168.2.2" # Ad-blocking counters # blockedDomains=840680 adsBlocked=0 adsWeek=0 adsNew=0 adsPrevCount="" adsLastCount="" # Dnsmasq settings # dsSetting=on logAsync= cacheSize= bogusPriv= domainNeeded= loqQueriesExtra= # Messaging # --------------------------------------------------- END FILE
I wonder how logging got that state logging=Fixed. Thanks!!!![]()
I made changes to the logic when switching state of adblocking or logging.
Will be part of the next Diversion update.
If you wiped the router and with it /jffs/* and did not uninstall Diversion first and the drive is still attached, then:The router was wiped out. So I set all the settings from scratch.
As the flash drive was still attached, tried running diversion install script. The install script tried to merge with earlier file, I guess. Somewhere the settings got mixed up.
[ ! ] Found a previous Diversion Standard installation
at /tmp/mnt/sda1/entware
1. Restore previous installation, keeping settings
(recommended)
2. New installation, deleting previous installation
Enter your selection [1=Restore 2=New]
The function restore should have kicked in:
Did you see that prompt?Code:[ ! ] Found a previous Diversion Standard installation at /tmp/mnt/sda1/entware 1. Restore previous installation, keeping settings (recommended) 2. New installation, deleting previous installation Enter your selection [1=Restore 2=New]
OK, could you post the Diversion install and update logs, also found in sf.Yes, I did.
I don't know if it's related. I enabled AiCloud and that messed up with my pixelserv IP. So diversion could not start pixelserv at all as that particular IP was being used by AiCloud. Later on after I disabled AiCloud which fixed the pixelserv issue. But the logging issue remained.
/opt/share/diversion/log/Diversion-install.log has this content:
Diversion install log Sun, 26 Aug 2018 04:53:04 -0700
[ i ] Checking router
[ ? ] Asuswrt-Merlin
[ ? ] dos2unix
[ ? ] Netstat
[ ? ] Compatible device(s)
[ ? ] Internet
[ i ] Router check complete
[ ? ] All clear to install Diversion 4.0
[ i ] But first, let's add some color!
[ ? ] theme.div integrated
____________________________________________________
[ ? ] Select a theme that works best in your
SSH client. All colors in use are shown.
1. standard standard ? ? Done
standard standard i ? Error
standard standard standard
2. green green ? ? Done
green green i ? Error
green green green
3. blue blue ? ? Done
blue blue i ? Error
blue blue blue
4. blue_on_white blue_on_white ? ? Done
blue_on_white blue_on_white i ? Error
blue_on_white blue_on_white blue_on_white
5. high_contrast high_contrast ? ? Done
high_contrast high_contrast i ? Error
high_contrast high_contrast high_contrast
6. basic basic [ ? ] [ ? ] [ Done ]
basic basic [ i ] [ ? ] [ Error ]
This basic theme may not show actual services
states due to the lack of colors.
Select Diversion theme: [1-6]
? Select Diversion Edition to install
1. Diversion Lite SSH UI, Entware,
no pixelserv-tls
2. Diversion Standard SSH UI, Entware,
with pixelserv-tls
Select Edition [1-2 e=Exit]
i Checking port 443 availability
? Port 443 is available
i Reserving one IP address for pixelserv-tls
! DO THIS NOW: Log into this routers WebUI
- Go to LAN > DHCP Server
- Adjust "IP Pool Starting Address" from the
standard xxx.xxx.xxx.2 (typically 192.168.1.2)
to xxx.xxx.xxx.3 (e.g 192.168.1.3)
(xxx.2 would be the reserved address)
- Make sure the reserved address is not used
by your other devices
- Then click "Apply"
You will need to enter the IP address next
! Press [Enter] to continue when ready
Enter pixelserv-tls IP Address:
? 192.168.2.2 is a valid IP address
i checking if 192.168.2.2 is available to use
? pixelserv-tls IP IP address set to 192.168.2.2
? Select Logging state
Dnsmasq can create a log file of all DNS queries.
The log is helpful for the curious, will show
stats in the header and allow the weekly stats
report to be run.
Logging can be enabled or disabled anytime.
Enable logging now? [1=Yes 2=No] ____________________________________________________
i Supporting SmallNetBuilder.com
To support SmallNetBuilder.com, some domains are
added to the whitelist to allow ads on their
websites.
Please do not remove them. Thanks
! Press [Enter] to acknowledge
i Probing for Entware
i Entware not installed, running checks
! Corrected invalid Entware symlink
? Entware checks passed
? Select device to install Entware to
1. /tmp/mnt/pdas001
2. /tmp/mnt/usb2
Select device [1-2]
i Running device checks
? Device checks passed
? Diversion is now ready to install,
this process runs fully automatic.
i Creating install directory at /tmp/mnt/pdas001/entware
i Installing Entware (armv7), using external script
Info: Checking for prerequisites and creating folders...
Warning: Folder /opt exists!
Info: Opkg package manager deployment...
Info: Basic packages installation...
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Installing entware-opt (227000-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/entware-opt_227000-3_all.ipk
Installing libc (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libc_2.23-8_armv7-2.6.ipk
Installing libgcc (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libgcc_7.3.0-8_armv7-2.6.ipk
Installing libssp (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libssp_7.3.0-8_armv7-2.6.ipk
Installing librt (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/librt_2.23-8_armv7-2.6.ipk
Installing libpthread (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libpthread_2.23-8_armv7-2.6.ipk
Installing libstdcpp (7.3.0-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libstdcpp_7.3.0-8_armv7-2.6.ipk
Installing entware-release (1.0-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/entware-release_1.0-2_all.ipk
Installing zoneinfo-asia (2018e-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/zoneinfo-asia_2018e-1_armv7-2.6.ipk
Installing zoneinfo-europe (2018e-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/zoneinfo-europe_2018e-1_armv7-2.6.ipk
Installing findutils (4.6.0-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/findutils_4.6.0-1_armv7-2.6.ipk
Installing terminfo (6.1-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/terminfo_6.1-1_armv7-2.6.ipk
Installing locales (2.23-8) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/locales_2.23-8_armv7-2.6.ipk
Installing grep (2.26-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/grep_2.26-1_armv7-2.6.ipk
Installing libpcre (8.41-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libpcre_8.41-2_armv7-2.6.ipk
Installing opkg (2011-04-08-9c97d5ec-17b) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/opkg_2011-04-08-9c97d5ec-17b_armv7-2.6.ipk
Installing entware-upgrade (1.0-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/entware-upgrade_1.0-1_all.ipk
Entware uses separate locale-archive file independent from main system
Creating locale archive - /opt/usr/lib/locale/locale-archive
Adding en_EN.UTF-8
Adding ru_RU.UTF-8
You can download locale sources from http://pkg.entware.net/sources/i18n_glib223.tar.gz
You can add new locales to Entware using /opt/bin/localedef.new
Upgrade operations are not required
Configuring libgcc.
Configuring libc.
Configuring libssp.
Configuring libpthread.
Configuring librt.
Configuring terminfo.
Configuring libpcre.
Configuring grep.
Configuring locales.
Configuring entware-upgrade.
Configuring opkg.
Configuring zoneinfo-europe.
Configuring zoneinfo-asia.
Configuring libstdcpp.
Configuring entware-release.
Configuring findutils.
Configuring entware-opt.
Info: Congratulations!
Info: If there are no errors above then Entware was successfully initialized.
Info: Add /opt/bin & /opt/sbin to your PATH variable
Info: Add '/opt/etc/init.d/rc.unslung start' to startup script for Entware services to start
Info: Found a Bug? Please report at https://github.com/Entware/Entware/issues
? Entware (armv7sf-k2.6) install complete
? Diversion directory structure created
at /opt/share/diversion
i Getting Diversion Standard files from
https://diversion.ch/diversion/4.0
? functions.div integrated
? install.div integrated
? post-conf.div integrated
? post-mount.div integrated
? rc.func.div integrated
? rotate-logs.div integrated
? S80pixelserv-tls integrated
? theme.div integrated
? update-bf.div integrated
? write-config.div integrated
i Checking white and blacklists
? Whitelist created
? Blacklist created
? Wildcard blacklist created
i Probing for pixelserv-tls
i Installing pixelserv-tls
Installing pixelserv-tls (2.1.1-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/pixelserv-tls_2.1.1-1_armv7-2.6.ipk
Installing libopenssl (1.0.2o-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libopenssl_1.0.2o-1_armv7-2.6.ipk
Installing zlib (1.2.11-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/zlib_1.2.11-2_armv7-2.6.ipk
Place ca.crt and ca.key to /opt/var/cache/pixelserv before starting HTTPS mode.
Start options can be adjusted via /opt/etc/init.d/S80pixelserv-tls.
See 'pixelserv-tls -h' for details
Configuring zlib.
Configuring libopenssl.
Configuring pixelserv-tls.
? pixelserv-tls installed
i Creating pixelserv-tls certificates
? pixelserv-tls certificates created
i Checking /jffs/scripts entries
? dnsmasq.postconf entry added
? post-mount entry added
? services-stop entry added
i Initializing Diversion
i Running update-bf.div to create the blocking file
preparing temporary whitelist
updated /jffs/shared-Diversion-whitelist
refreshing Skynet to whitelist domains in shared-Diversion-whitelist
including /jffs/shared-Skynet-whitelist in Diversion
including /jffs/shared-Skynet2-whitelist in Diversion
downloading Standard blocking file, 1 hosts files
using 192.168.2.2 as blocking IP, adding "::" as IPv6 blocking IP
getting hosts file 1 of 1, preprocessing file
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
processing file 1 done
removing whitelisted content, sorting file
this may take a while...
adding IPv6 blocking entries
blocking file Standard update complete
i (Re)starting pixelserv-tls
Starting pixelserv-tls (Diversion)... done
? pixelserv-tls is running
i Checking cron jobs
? Blocking file update
? Rotate logs
? Ads counter
i Checking dnsmasq.conf entries
? Additional hosts
? Log facility
? Diversion Standard v4.0 install complete
Diversion install exited or aborted
END FILE
/opt/share/diversion/log/Diversion-update.log has this content:
Diversion update log Sun, 07 Oct 2018 21:27:48 -0700
✔ Entware is already installed
✔ backup.div integrated
✔ functions.div integrated
✔ post-conf.div integrated
✔ post-mount.div integrated
✔ rc.func.div integrated
✔ rotate-logs.div integrated
✔ stats.div integrated
✔ S80pixelserv-tls integrated
✔ theme.div integrated
✔ update.div integrated
✔ update-bf.div integrated
✔ write-config.div integrated
✔ dnsmasq.postconf
✔ post-mount
✔ services-stop
✔ Blocking file
✖ pixelserv-tls not running, restarting...
✖ pixelserv-tls not running, check syslog for errors
✔ Blocking file update
✔ Backup
✔ Diversion update check
✔ Additional hosts
✔ Diversion Standard v4.0.2 update complete
END FILE
I believe this is where it all happened, you pressed CTRL-C at some point during the install.Diversion install exited or aborted
Welcome To SNBForums
