Diversion Diversion - the Router Ad-Blocker
I have on the Desktop. But the issue is occurring on both my iMacs, and the iPhone App, and the iPhone browser. So, I'm not sure if it would bd related to the cache?
Sent from my iPhone using Tapatalk Pro
Wouldn't hurt to clear all your devices' caches and give it a go. I feel that if the issue were Diversion related the pages wouldn't load at all, let alone parts of them.
Also, try accessing the page on your iPhone browser when you are not connected to your wifi and see how that goes.
When I swap to 4G on my iPhone the Reddit App works and I can access Reddit in the iOS Safari browser.
 1: https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
 2: https://adaway.org/hosts.txt
 3: https://hosts-file.net/ad_servers.txt
 4: http://www.malwaredomainlist.com/hostslist/hosts.txt
 5: https://raw.githubusercontent.com/StevenBlack/hosts/master/alternates/fakenews/hosts
 6: http://sbc.io/hosts/alternates/gambling/hosts
 7: http://sbc.io/hosts/alternates/porn/hosts
 8: http://sbc.io/hosts/alternates/social/hosts
 9: https://gitlab.com/ZeroDot1/CoinBlockerLists/raw/master/hosts
 10: https://raw.githubusercontent.com/azet12/KADhosts/master/KADhosts.txt
 11: https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/update.txt
This hosts file
blocks Reddit, but I added every single address to the Whitelist.
Maybe you did not?
I've added every *redd* instance, exept non-reddit domains and ads.reddit.com to the whitelist and it works fine here.
a.thumbs.redditmedia.com # reddit test
about.reddit.com # reddit test
alb.reddit.com # reddit test
amp-reddit-com.cdn.ampproject.org # reddit test
b.thumbs.redditmedia.com # reddit test
c.thumbs.redditmedia.com # reddit test
d.thumbs.redditmedia.com # reddit test
e.reddit.com # reddit test
e.thumbs.redditmedia.com # reddit test
emoji.redditmedia.com # reddit test
en.reddit.com # reddit test
events.reddit.com # reddit test
events.redditmedia.com # reddit test
external-preview.redd.it # reddit test
f.thumbs.redditmedia.com # reddit test
fr.reddit.com # reddit test
g.redditmedia.com # reddit test
gateway.reddit.com # reddit test
gp.reddit.com # reddit test
hw.reddit.com # reddit test
i.redd.it # reddit test
i.reddit.com # reddit test
it.reddit.com # reddit test
m.reddit.com # reddit test
meta-api.reddit.com # reddit test
mod.reddit.com # reddit test
new.reddit.com # reddit test
np.reddit.com # reddit test
nsfw.reddit.com # reddit test
oauth.reddit.com # reddit test
old.reddit.com # reddit test
oops.redditmedia.com # reddit test
pixel.redditmedia.com # reddit test
reddit-image.s3.amazonaws.com # reddit test
reddit-uploaded-media.s3-accelerate.amazonaws.com # reddit test
reddit-uploaded-video.s3-accelerate.amazonaws.com # reddit test
reddit.map.fastly.net # reddit test
redditgifts.s3.amazonaws.com # reddit test
sendbird.reddit.com # reddit test
ssl.reddit.com # reddit test
static.redditgifts.com # reddit test
styles.redditmedia.com # reddit test
us.reddit.com # reddit test
v.redd.it # reddit test
wh.reddit.com # reddit test
www.reddit.com # reddit test
www.redditgifts.com # reddit test
www.redditmedia.com # reddit test
www.redditstatic.com # reddit test
Maybe you did not?
I've added to the whitelist and Reddit is now working!! Thank you very much !!
@thelonelycoder, can you please add option "e" within the menu d->3? There are already options "1" for yes and "2" for no, but adding "e" would make the interface more consistent among different screens.
i.e. I use my iphone with Termius app, and within most of the menus I can use "e" as a back/exit option, but not on the Diversion update menu "d". Thing is, I choose "d"->"3" for to check for updates, then instead of using "e" to exit the menu (as there are no updates available), I need to choose "2" for to avoid a force update. The default keyboard on iphone show the letters, not the numbers, and means, I need to switch to numbers for choosing "2", but if option "e" would be there, then the workflow would be same as in the other menus, making navigation faster and more logical (at least for me)
Thank you!
I'm trying to reinstall everything for my new router. I have a freshly formatted FAT32 32GB USB Drive. And I am currently trying format it to EXT4 using the router. However, when I try to unmount I receive this output:
admin@RT-AX88U-E390:/tmp/home/root# umount -f /tmp/mnt/RT-AX88U
umount: can't unmount /tmp/mnt/RT-AX88U: Device or resource busy
I'm not sure how to overcome this Device or resource busy issue.
Install and use AMTM by @thelonelycoder
Looks like you need to update AMTM to the new version.
Yes, the newest version of amtm (1.6) has the tools built-in for formatting to various ext2,3,4 versions.
There's nothing on the USB Drive. Its formatted to FAT32 .... I'm trying to format it to EXT4 and do a fresh install of everything.
This is an interesting dilemma. I don't think this was considered when integrating the format ability in AMTM. If you try to install AMTM and the drive is not formatted to ext* it should use it's format ability to carry on with the install. What do you think @thelonelycoder ? :)
Edit: A person just needs to install AMTM and use it's abilities to format this drive.
Isn't AMTM installed directly to /jffs/scripts/? I don't believe that an EXTx formatted drive is necessary for its initial installation.
Bingo you are right sir!!!!
Okay, I'll proceed to install AMTM. Thanks everyone :)
I just tried to use the inbuilt Format tool in AMTM and received the same error. hmm I've formatted a number of usb drives, and external drives, using the RT-AC86U (which I've sold) and have not had this issue:
_________________| INFO |__________________
 This (re)formats your plugged in USB storage
 device to ext* filesystem.  The process
 erases all data and partitions on the device.
 After formatting, the router will reboot.
 To be on the safe side, remove all other
 attached USB devices before continuing.
 Authors: Zonkd, ColinTaylor, thelonelycoder
 https://www.snbforums.com/threads/ext4-disk-formatting-options-on-the-router.48302/page-2#post-455723
___________________________________________
 Continue? [1=Yes e=Exit] 1
 Select your device to format
  Again, this will erase all data and
  partitions on the selected device!
 1.  /tmp/mnt/RT-AX88U
 Select device [1-1 e=Exit] 1
[: 29.3G: bad number
 You selected the following device:
  /tmp/mnt/RT-AX88U
 This will delete ALL of the following:
  /dev/sda2  mounted as  /tmp/mnt/RT-AX88U
 1. Continue
 2. Return to device selection
 Enter selection [1-2 e=Exit] 1
 Select new filesystem
 2. ext2
 3. ext3
 4. ext4
 Set filesystem [2-4] 4
 Do you want to enable journalling?
 1. No journalling
 2. Enable journalling
 Enter selection [1-2] 1
 Do you want to set a device label?
 1. No label
 2. Set label
 Enter selection [1-2] 2
 Enter label: RT-AX88U
 Formatting /tmp/mnt/RT-AX88U now!
 Unmounting device(s)
  Filesystem(s) did not unmount
  See error above for reason
 amtm 1.6                by thelonelycoder
 The SNBForum Asuswrt-Merlin Terminal Menu
 RT-AX88U (aarch64) FW-384.8 @ 192.168.1.1
Try this command
Check to see if it unmounted then install.
Try this command
Same outcome :( :
ASUSWRT-Merlin RT-AX88U 384.8-2 Sat Dec  8 18:21:59 UTC 2018
