Diversion Diversion - the Router Ad-Blocker
Same outcome :( :
ASUSWRT-Merlin RT-AX88U 384.8-2 Sat Dec  8 18:21:59 UTC 2018
admin@RT-AX88U-E390:/tmp/home/root# umount -f /tmp/mnt/RT-AX88U
umount: can't unmount /tmp/mnt/RT-AX88U: Device or resource busy
Try the same command just remove the /tmp part. It should be /mnt/RT-AX88U
argh! lol
admin@RT-AX88U-E390:/tmp/home/root# umount -f /mnt/RT-AX88U
argh! lol
Are you able to reboot the router?
If you know how to format drives directly without using amtm then simply disable jffs on router, reboot it and you can do the unmount easily.
If you can reboot with the drive left in.
I'll rebo
I was just about to reply with the same suggestion. Doing it now :)
Yeah, I have tried that. I'll try another USB Drive soon. Out an about atm.
Sent from my iPhone using Tapatalk Pro
With Enable JFFS custom scripts and configs on and using amtm to format new USB Drive:
Formatting /tmp/mnt/KINGSTON now!
 Unmounting device(s)
umount: can't unmount /tmp/mnt/KINGSTON: Device or resource busy
  Filesystem(s) did not unmount
  See error above for reason
Without Enable JFFS custom scripts and configs on and using CLI:
admin@RT-AX88U-E390:/tmp/home/root# umount -f /tmp/mnt/KINGSTON
admin@RT-AX88U-E390:/tmp/home/root# umount -f /mnt/KINGSTON
I'm lost. I have no idea why this is occurring.
I might use Parallels (VM) on my iMac and install Debian, and format it that way.
Is Samba enabled? Maybe that prevents the unmount. It usually is with new firmware installation (file sharing or some such).
Isn't AMTM installed directly to /jffs/scripts/? I don't believe that an EXTx formatted drive is necessary for its initial installation.
It sure is. That's why the disk formatter is part of amtm and not Diversion.
Without JFFS enabled see if you can unmount the drive using web UI and then do the formatting manually.
Done, solved. All I had to do in Network Map>USB 3.0 Device was click on the mounted USB Device and in the "Information" tab click "Safely Remove disk" ... of course that unmounted the USB Drive.
admin@RT-AX88U-E390:/tmp/home/root# mke2fs -t ext4 -O ^has_journal /dev/sda1
mke2fs 1.42.13 (17-May-2015)
/dev/sda1 contains a vfat file system labelled 'KINGSTON'
Proceed anyway? (y,n) y
Creating filesystem with 7568400 4k blocks and 1892352 inodes
Filesystem UUID: 11f6b30c-2692-401b-b5c1-1a8608952b59
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
        4096000
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
Thank you @Asad Ali
Edit: Everything is installed and working. My LAN is Ad free, and Skynet is working well.
@thelonelycoder I see what you mean, the whitelist will become second nature for me after updating the Large blocking list.
@thelonelycoder, can you please add option "e" within the menu d->3? There are already options "1" for yes and "2" for no, but adding "e" would make the interface more consistent among different screens.
Sure, will be coming in the next update.
Thanks for pointing out the inconsistency.
What is the actual devices name, is it indeed "___RT-AX88U___"?
I do not know why, when I named the thumb drive RT-AX88U, the ____ were added to each side. Strange. The actual Router is named RT-AX88U E90 (something like that).
Edit: RT-AX88U-E390
