Preskitt.man
Depending on where I am running my VPN client (or not), I am getting results I don't understand.
My basic configuraiton:
Asus 86U with Merlin 384.15
ISP IP: 207.171.232.98
PIA Server: 192.116.118.168 (for OpenVPN) or 192.116.118.x for PIA client on PC. The VPN server is in Bay Area of CA.
Asus DNS settings:
Connect to DNS Auto : Yes
Forward Local Domain: No
Enable DNS Rebind: No
Enable DNSSEC: No
Prevent Auto DOH : Autu
DNS over TLS : Opportunistic
DNS Servers: 1.1.1.1 & 1.0.0.1 (Cloudfare)
DNS Filter: On
Filter Mode: Router
DNS1: 1.1.1.1
DNS2: 1.0.0.1
Client List: (empty)
The IPV4 connection on my properties page is the default: Obtain DNS Server address automatically.
Now with all that out of the way, I went to ipleak.com with 3 different configurations:
1: Open VPN Client on Router: On & PIA client on server: Off
DNS addresses returned:
DNS1: 172.68.135.211 (San Jose, CA)
DNS2: 209.222.18.218 (in Brooklyn, NY)
Neither of these address make sense to me
2: Open VPN Client on Router: Off & PIA Client on server : Off
DNS address returned:
DNS1: 162.158.141.83 (in Phoenix, AZ)
DNS2: None
Note that DNS is same as DNS1 in Case 1
3: Open VPN Client On Router: Off & PIA client on server: On
DNS1: 199.116.118.172 (Address of PIA server in CA)
DNS2: None
This one actually makes sense: My PIA client specifies the use of PIA DNS and this IP is the address of the PIA server.
I am guessing that 162.158.141.83 is the DNS server that my ISP points to as I am in AZ as is the 162... address.
I am also guessing that the DNS addresses returned when using the OpenVPN client on ASUS are picked by the PIA/OpenVPN server in San Jose
Which leaves open two questions,
1: Why, when PIA is totally disabled am I not using Cloudfare (with DOT)
2) When using OpenVPN client on ASUS, how do I specify Cloudfare (DOT or otherwise)
I have tried specifying: push "dhcp-option DNS 1.1.1.1" and simly dhcp-option DNS 1.1.1.1 and neither seemed to have any effect.
Asus DNS settings:
Enable DNSSEC: No
DNS Filter: On
Filter Mode: Router
DNS1: 1.1.1.1
DNS2: 1.0.0.1
DNS2: None
DNS2: None
