Voxel
Part of the Furniture
Unfortunately.
I'm not the only one to think this is a bad idea:
https://www.theregister.co.uk/2018/...oh_as_dns_privacy_feature_becomes_a_standard/
Interesting... Thanks for sharing this link.
Voxel.
Unfortunately.
Yupp, saw that one too. Hard to control, I just dread the day when devices are hardcoded to use it and bypass my dns-proxy... even worse in an enterprise environment.![]()
nvram get stubby
/etc/init.d/stubby start
Stubby is not enabled in nvram. Exit.
nvram get stubby does not return anything in the console.
I followed the instructions here: https://www.voxel-firmware.com/Downloads/Voxel/R7800-Voxel-firmware/Stubby/readme.txt
I don't see anywhere in there where it talks about nvram and stubby. The note at the top states: NOTE: it is included into firmware since 1.0.2.61SF and that's the version of the firmware I'm on. I didn't do any of the package installations because all the packages were already installed. I verified by running the opkg list-installed command.
Start here by looking in the forum thread.
If you use Voxel's FW I think it's fair to give it a "like" as well - at least.
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-61sf.49358/
Good luck and hope you get Stubby working now. But beware it's an add-on, not Voxels code.
t=$(while true; do T=$(logger "DNSCrypt service validation";ping -c2 -q 1.1.1.1 && nslookup google.com || (/etc/init.d/dnscrypt-proxy-2 restart; logger "dnscrypt service restarted")); sleep 60; done) &
What version of firmware do you use? My 1.0.2.61SF has stubby/unbound etc already included into firmware. So no necessity to install it (not this thread).hello. does anyone know why am getting the error message cant load library 'libunbound.so.2' when viewing /var/log/stubby.log? i was learning/experimenting how to install stubby etc. I also reset router back to factory defaults with the same issues. any info will help this noob, thanks.
Voxel.
Most proper way in your case would be:i was able to get stubby working again by force downgrading libunbound_1.7.3-6_ipq806x.ipk. This removed the linbunbound.so.2 error i was having, maybe this info will help others one day.
wget --no-check-certificate https://www.voxel-firmware.com/Downloads/Voxel/R7800-Voxel-firmware/DNSCrypt-Proxy-2/dnscrypt-proxy-2_2.0.18-1_ipq806x.ipk
/bin/opkg install dnscrypt-proxy-2_2.0.18-1_ipq806x.ipk
Info for R7800 users of DNSCrypt-Proxy v2:
New version is available (2.0.18). Similar installation.
Code:wget --no-check-certificate https://www.voxel-firmware.com/Downloads/Voxel/R7800-Voxel-firmware/DNSCrypt-Proxy-2/dnscrypt-proxy-2_2.0.18-1_ipq806x.ipk /bin/opkg install dnscrypt-proxy-2_2.0.18-1_ipq806x.ipk
but totally different implementation. Also: cloudflare and some other Scandinavian servers are enabled by default.
Release notes:
- Official builds now support TLS 1.3.
- The timeout for the initial connectivity check can now be set from the command line.
- An Accept: header is now always sent with GET queries.
- BOMs are now ignored in configuration files.
- In addition to SOCKS, HTTP and HTTPS proxies are now supported for DoH servers.
P.S.
kamoj : it should be useful for you.
Voxel.
Might be just coincidence but after upgrade of DNSCrypt to 2.0.18 my router started to disconnect WiFi frequently (similar frequency to stock .60 FW). For now I've rolled back to 2.0.16.
If you are using latest version of my firmware then dnscrypt proxy 2.0.19 (latest) is already included into firmware. No any needs to install it manually. See my notes (latest firmware thread) re: how to enable it.Update: Went to actual Voxel site and noticed under the R9000 a newer package I downloaded and installed successfully.
Welcome To SNBForums
