DNSMasq local DNS
OK I tried it on my router and it works OK. I set the "Domain Name" to "lan" on the router and added the following line to dnsmasq
address=/web.lan/web2.lan/sonarr.lan/192.168.1.22
C:\Users\Colin>nslookup web.lan
Server:  router.asus.com
Address:  192.168.1.1
Address:  192.168.1.22
C:\Users\Colin>nslookup sonarr.lan
C:\Users\Colin>nslookup web2.lan
So there must be something different about your setup that we're not seeing.
After this I tried the suggested address=/web.lan/web2.lan/sonarr.lan/192.168.1.2 to dnsmasq.conf.add (which by the way is the only line in this file).
C:\Users\Joakim>nslookup sonarr.lan
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
The router can't even do a reverse lookup on it's own name which suggests to me that your dnsmasq configuration is corrupted.
How are you creating the dnsmasq.conf.add file? You must use a "unix" editor and not a Windows one (like Notepad or WordPad).
That is so weird. I have no special settings I think. Does it take long time for the dns settings to take effect? I have tried waiting for a while, maybe 10 min. No success.
service restart_dnsmasq
No internet access, no router access. Still connected to router through wired.
If I reboot I can't even get the wired to connect.
That's a known bug on Windows nslookup if you have IPv6 enabled...
I wondered about that, but post #17 suggests that he's not using IPv6. In fact his settings are almost identical to mine and I'm not seeing that problem :confused:. Plus, the "Unknown" message only appeared after he created the dnsmasq.conf.add file.
Scroll down a bit in #17.....he's getting an IPv6 address from Taredo....
I'm guessing it's these two lines that I don't have.
   DHCPv6 IAID . . . . . . . . . . . : 150994944
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-76-31-1B-74-D4-35-E9-FE-66
I never would have spotted that. Thanks for the tip.
So if the "Unknown" message is a red herring, there's still something fundamentally misconfigured if he looses access to the internet and the router!
Further down.....
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   Autoconfiguration Enabled . . . . : Yes
   IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:..........
I'll look through the thread and see if I can add anything....
Maybe try disabling Taredo....
netsh interface teredo set state disabled
via admin prompt.....then reboot or disable/enable the adapter.
Further down.....
Yes, that was the part I was referring to. I don't have IPv6 but Teredo still gives me a pseudo IPv6 address, but not the DHCPv6 stuff.
   IPv6 Address. . . . . . . . . . . : 2001:0:9d38:78cf:2cce:199:ade3:94a3(Preferred)
   Link-local IPv6 Address . . . . . : fe80::2cce:199:ade3:94a3%11(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
Would it be the problem of having two IP's answer for requests if the Router's Domain name is, say router.lan and then configure a web server to listen to another IP on that router with a domain such as sonarr.lan?
With an entry such as this:
it may work but not with a wildcard entry like this:
address=/lan/192.168.1.22
Could you post the full /etc/dnsmasq.conf before and after adding the dnsmasq.conf.add?
I have replaced / with slash, get a blocked message from this forum if not.
Here's etc "slash" dnsmasq.conf
https://pastebin.com/bEse2TXy
Here's etc "slash" hosts.dnsmasq
https://pastebin.com/iTkcxitu
Those files don't contain any changes from dnsmasq.conf.add. We need to see the files after the changes have been applied.
That's the thing, I am not able to post that, as soon as I edit the dnsmasq.conf.add the router stops working with my PC. So I cannot check anything after this.
Does merely creating the dnsmasq.conf.add file stop your router working :confused:? Or is it when you apply the change, i.e. rebooting the router or issuing a "service restart_dnsmasq"?
Creating it is fine, but applying changes makes it stop working :(
Can you try this instead. Log onto the router using something like PuTTY and...
cd /jffs/configs
echo "address=/web.local/web2.local/sonarr.local/192.168.1.2" > dnsmasq.conf.add
sync
reboot
cd /jffs/configs
sync
reboot
Finally got it working, I did format the JFFS partition and tried the above you said. And now I got zero problems this far.
Something was off with the partition maybe?
Yeah something was messed up somewhere. I blame the aliens and their pesky flying saucers.:)
Glad you got it working.
