DnsMasq
The firmware regenerates /etc/dnsmasq.conf whenever dnsmasq restarts. Your opportunity to modify it comes from either 1) custom config files like /jffs/configs/dnsmasq.conf.add (which gets appended by the firmware)or 2) custom scripts in /jffs/scripts such as dnsmasq.postconf where you can be more creative. After you restart dnsmasq, you should see your custom changes reflected in /etc/dnsmasq.conf.
...."you should see your custom changes reflected in /etc/dnsmasq.conf" - is this in the GUI?
No, in the SSH session. Type
cat /etc/dnsmasq.conf
I keep reading..."Create configuration file for dnsmasq"
Does that mean the there is an actual file that is created that can be edited later?...if so, where is that configuration file located and how do i access it later?
Ok.. so I have entered the script into the ssh client.. it said "done"... I lost internet and had to reboot the router.... it doesn't seem to have worked since Bing's resitricted mode was not enabled.
echo “address=/www.bing.com/204.79.197.220” > /jffs/configs/dnsmasq.conf.add
service restart_dnsmasq
Actually, I don't have internet at all on that router... how can I undo what I did?
What is at the end of
Ok, it’s my bad advice then on the quote marks.
Run my commands again without the quote marks and check the file again.
Or run
rm /jffs/configs/dnsmasq.conf.add
To undo everything
No, your second attempt overwrote the first one. All my sins are hidden now. :oops:
haha.. no worries.. luckily my modem also has wifi, so I had turn it on so I would be able to connect lol.
Thank you so much for that.... now... would you like the opportunity to "redeem" yourself? lol -
gonna through you a curve ball.....
In tomato, I use a script to force SafeSearch on all google's domains... the script is...
tlds="com ac ad ae com.af com.ag com.ai al am co.ao com.ar as at com.au az ba com.bd be bf bg com.bh bi bj com.bn com.bo com.br bs bt co.bw by com.bz ca com.kh cc cd cf cat cg ch ci co.ck cl cm cn www.g.cn com.co co.cr com.cu cv com.cy cz de dj dk dm com.do dz com.ec ee com.eg es com.et fi com.fj fm fr ga ge gf gg com.gh com.gi gl gm gp gr com.gt gy com.hk hn hr ht hu co.id ir iq ie co.il im co.in io is it je com.jm jo co.jp co.ke ki kg co.kr com.kw kz la com.lb com.lc li lk co.ls lt lu lv com.ly co.ma md me mg mk ml com.mm mn ms com.mt mu mv mw com.mx com.my co.mz com.na ne com.nf com.ng com.ni nl no com.np nr nu co.nz com.om com.pa com.pe com.ph com.pk pl com.pg pn com.pr ps pt com.py com.qa ro rs ru rw com.sa com.sb sc se com.sg sh si sk com.sl sn sm so st com.sv td tg co.th com.tj tk tl tm to tn com.tn com.tr tt com.tw co.tz com.ua co.ug co.uk us com.uy co.uz com.vc co.ve vg co.vi com.vn vu ws co.za co.zm co.zw"
mkdir -m 777 -p /tmp/etc/dnsmasq/hosts
for tld in $tlds
do
echo "216.239.38.120 www.google.$tld"
done
} > /tmp/etc/dnsmasq/hosts/safesearh.hosts
Can this script be used in Merlin via ssh as well?
for tld in $tlds
do
done
With a bit of modification. The path in the last line should be changed to /jffs/configs/hosts.add
You don’t need the mkdir line.
When done, restart dnsmasq again.
So it would look like this?
for tld in $tlds
do
done
} > /jffs/configs/hosts.add
Yes. Although I have to think about why your quotes would work and not mine. Maybe it’s because my iPad converted to curly quotes while typing instead of straight quotes.
To get your script loaded, experiment with the nano editor in SSH. I assume learning vi is a bridge too far at this time.
Start your script file with
#!/bin/sh
before the tlds= line.
like this?
#!/bin/sh
for tld in $tlds
do
done
If it does not work or if I lose connectivity... I can just use
to clear it or is that only for the dnsmasq?
like this?
#!/bin/sh
for tld in $tlds
do
done
rm /jffs/configs/hosts.add
But before you restart dnsmasq, cat /jffs/configs/hosts.add to make sure it looks like a proper hosts file first. Only then restart dnsmasq, if it looks wrong rm it.
Dave... thank you so much for all your help and patience!
I know it must be frustrating at times to deal with complete noobs like me!
It's now looking like I will be keeping this firmware... just a couple of more settings I need help with and I think I'm good.
Thank, thank you!!
Thank, thank you!!
Glad to help. We were all in your shoes once. Now we pay it forward!
