Ranger802004
Domain VPN Routing is a tool used to route specific website domains to specific VPN tunnels or override all traffic being routed to a VPN tunnel to directly route through a WAN interface.
***v3.1.1 Release****
This is the release information regarding v3.1.1, please read the notes carefully prior to installing.
Readme - https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/domain_vpn_routing/readme.txt
Script - https://raw.githubusercontent.com/R...main/domain_vpn_routing/domain_vpn_routing.sh
Install Command:
Support:
- Submit a ticket via GitHub here.
Release Notes:
v3.1.1 - 04/29/2025
Enhancements:
- If DNS-over-TLS is enabled and servers are configured on the system DNS-over-TLS DNS server list, dig will configure use for DNS-over-TLS by randomly selecting a DNS-over-TLS DNS server.
- Python3 and dig are required to be installed for this functionality.
- An existing DNS configuration for the interface in Domain VPN Routing will override this functionality.
- Added debug logging for DNS-over-TLS configuration during querypolicy function execution.
Fixes:
- Fixed an issue with IPv4 unreachable rules being created for VPN interfaces due to a missing default route for the VPN routing table.
- Fixed an issue where restoreasncache was executing when restoring an individual policy, this will still execute when restoring all policies.
- Fixed issues with erroneous data being ingested by dig.
- Fixed an issue with dig applying DNS Server configuration incorrectly and causing unreturned data from queries.
- Minor fixes and optimizations
v3.1.0 - 04/12/2025
Enhancements:
- Added functionality to cache ASN IP Subnets for faster restoration from reboot or service restart. This can be enabled or disabled via the ASNCACHE configuration option. Default: Disabled
- ASN queries will now check existing IPSets for IP Subnets that are no longer applicable to the ASN and remove them.
- New configuration options to enable DNS-over-TLS for an interface if a custom DNS Server is configured for it, the options in the configuration menu will become displayed when a DNS Server is configured. DoT requires dig to be installed to function properly.
Fixes:
- Fixed an issue when Domain VPN Routing is getting system parameters it was not applying the boot delay timer configuration.
- Fixed an issue where dig,jq,python3 packages were being checked before Entware was mounted. Will now continue to check if Entware is mounted if Entware is detected as being installed until it times out after 30 checks.
v3.0.6 - 03/30/2025
Fixes:
- Fixed an issue causing errors during installation when the firewall-start script does not exist and the Firewall Restore setting is disabled.
v3.0.5 - 02/08/2025
Fixes:
- Fixed an issue where comments for IPSets were greater than 255 and causing the IP Addresses to not be added.
- Fixed an issue for errors being generated from null data being returned from AdGuardHome log parsing and ASN queries.
- Fixed other minor issues
v3.0.4 - 11/27/2024
Fixes:
- Fixed an issue that would add erroneous CNAME values into a policy domain list when dig was being used to lookup CNAMES.
- Fixed an issue when using the deleteip function to delete an IP address.
v3.0.3 - 11/08/2024
Fixes:
- Fixed an issue with new installations of Domain VPN Routing.
v3.0.2 - 11/05/2024
Enhancements:
- Added functionality to query the AdGuardHome log. This can be enabled or disabled via the QUERYADGUARDHOMELOG configuration option.
- Created option to enable/disable Domain VPN Routing under configuration menu.
- During uninstallation, a prompt has been added to ask to back up the configuration. When reinstalling Domain VPN Routing a backup file will be checked for existence and prompted to restore configuration.
- Removed log message regarding No ASNs being detected if queryasn function is being executed by querypolicy for all policies.
- Enhanced prompts in querypolicy mode.
- Added log message stating length of processing time for querypolicy function.
- Minor optimizations.
Fixes:
- Fixed script locking mechanism when executing querypolicy or queryasn from the UI menu.
- Fixed issue where ASNs were not queried by cron job if no domain policies were created.
v3.0.1 - 10/26/2024
Enhancements
- Added functionality to add ASNs to be routed over an interface.
- Added ADDCNAMES to Show Policy menu when viewing a policy.
- Optimized functionality to generate interface list when creating or editing a policy or ASN.
- Optimized functionality for boot delay timer and setting process priority.
- System Information under Configuration menu now shows status of dig and jq being installed.
- Domain VPN Routing will now check for WAN being connected and will error out when executing querypolicy, queryasn, or update if WAN is not connected.
Fixes:
- Fixed an issue where IP FWMark rules were erroneously being deleted when editing or deleting a policy.
- Fixed an issue with executing the kill function to kill Domain VPN Routing processes, this was also happeneing in update mode.
- Fixed grammatical error on Main Menu for queryasn.
- Fixed error when editing a policy and getting an error for no NEWASININTERFACE variable.
- Fixed an erroroneous file being created under /jffs/configs/domain_vpn_routing/policy_all_domainlist ***It is safe to delete this file***
- Various minor fixes
v3.0.0 - 10/14/2024
Enhancements:
- Added functionality to support wildcards for subdomains. Example: *.example.com ***Requires DNS Logging to be enabled***
- Added DNS Overrides for VPN Client interfaces, when a policy is configured with a specific interface it will use the system default DNS Server unless a DNS override is configured for that specific interface in the configuration menu.
- Domain queries will now utilize dig if it is installed and will bypass use of nslookup.
- If dig is installed, a policy can be configured to allow CNAMES of domains to be added to the policy domain list automatically during query execution. This is disabled by default for existing policies and can be enabled using the editpolicy function.
- IP Version will now be displayed under System Information located in the Configuration menu.
Fixes:
- Reduced names of IPSets to allow policy names to have a max length of 24 characters.
- Fixed issue that caused RT-AC68U and DSL-AC68U to lock up on execution due to limitation of 2 OpenVPN Client slots.
- Domain VPN Routing will now check the IP version and operate in a compability mode for older versions. If an optional binary is installed Domain VPN Routing will test and use the newer version of the ip binary between the system and optional binary.
- Fixed an issue with beta update channel.
- Fixed an issue where ip rules were not being deleted when an unreachable rule was being created to block traffic for a VPN interface being down.
- Fixed minor issues with IPv6 routing rules.
Install Command:
/usr/sbin/curl -s "https://raw.githubusercontent.com/Ranger802004/asusmerlin/main/domain_vpn_routing/domain_vpn_routing.sh" -o "/jffs/scripts/domain_vpn_routing.sh" && chmod 755 /jffs/scripts/domain_vpn_routing.sh && sh /jffs/scripts/domain_vpn_routing.sh install
Support:
Release Notes:
v3.1.1 - 04/29/2025
Enhancements:
Fixes:
v3.1.0 - 04/12/2025
Enhancements:
Fixes:
v3.0.6 - 03/30/2025
Fixes:
v3.0.5 - 02/08/2025
Fixes:
v3.0.4 - 11/27/2024
Fixes:
v3.0.3 - 11/08/2024
Fixes:
v3.0.2 - 11/05/2024
Enhancements:
Fixes:
v3.0.1 - 10/26/2024
Enhancements
Fixes:
v3.0.0 - 10/14/2024
Enhancements:
Fixes:
