SteevieWeevie
Yes my ISP provider says only his chinese modem will be compatiable (its a local isp provider..) Thanks i will give a try to this build and take the forum help if any issue i get..
One quick question, my router is in the ground floor , will my 2.4 GHz signal will be reachable in the second floor? i am getting drop only in that location. Or i am expecting too much from the router ?
If it doesn't work on your ISP right now then at the very least you don't have much to lose by giving this a try.
If you mean a ground floor, first floor, second floor arrangement, then I would say you are asking a lot from a WiFi signal to be able to propagate that far and through several layers of physical and electrical interference. The 68U is a good router but it won't work miracles.
