Honestly, i have so many threads, i actually just went upstairs to get the right information LOL, YES i do have the AC86U, which was running merlin, i just pm you RE open reach modem
Mine seems to work fine and I do not have the same problem.Hi there,
I do not own a DSL anymore and I cannot test this...https://github.com/gnuton/asuswrt-merlin.ng/issues/29
Would anybody check this out?
Thanks a lot.
From the logs it looks fine to me..
It's a long time I do not have a DSL connection now.. and I'm still actively maintaining this project.Mine seems to work fine and I do not have the same problem.
@GNUton, if you don't have a dsl anymore are you still going to continue with development?
Thanks, good to hear.It's a long time I do not have a DSL connection now.. and I'm still actively maintaining this project.
The DSL-AC68U is still my main router to access the internet but I do not use its DSL capabilities for now.
Hi there,
Thanks a lot.
Are you going to incorporate 384.15 into your GNUtonwrt realm? I am curious to see how well the add-ons adapt to the dsl branch.Hi there,
Thanks a lot.
Hi there,
Thanks a lot.
I'm not having this problem. It's all working great for me. ThanksHi there,
Thanks a lot.
Can indeed confirm this bug, and the workaround does rectify it.
Hi there,
I have built a new pre-release https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.14_2-gnuton0_alpha1 which is waiting for some testers.
I would like to thank all the people who help me in testing the firmware and support other users! cheers mates!
I just noticed Asus has released new binary blobs so I will update the firmware most probably this weekend. No idea what are the changes yet there.
Hi there,
I have merged the latest ASUS binaries in 384.14_2 and here is the build: https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.14_2-gnuton0_alpha2
This will require more testing than the alpha1 because ASUS has changed a few functions.
So once again, please test and let me know if the latest build works for you. Expecially the DSL part which I cannot test by myself.
Thanks a lot.
Hi there,
Thanks a lot.
I can see lots of changes and bug fixes from Asus in their latest release.
I will test this alpha 2 of yours over the weekend and report back.
I don't doubt it will be as plain sailing as usual.
bricked my router this one, cant seem to get into recovery either. lovely stuff.
The cautionary from @GNUton was clear - which is why I held off on the alpha 2 until ample time to play with the alpha [expect issues]
If you went ahead after reading my post above - then...
While router is powered on - press and hold the reset button for at least 6 seconds - then press the power button and hold it in while still hanging onto the reset button ... wait until the power LED blinks slowly - then release. Run Rescue program asap with Asus Stock firmware selected. Do not restore settings from backup - reconfigure manually.
I suggest you stick with GNUton 384.14_0 stable release - it is rock steady if carefully an correctly configured.
Welcome To SNBForums
