Did you install uiDivStats on the second one?
There's nothing to explain. They just have different bootloaders because one was manufactured more recently than the other.... but I can't explain the bootloader.
I was thinking about that to, but the one with 1.0.0.8 is manufactured more recently, the one with 2.0.0.3 is older so DOM has nothing to do with it.There's nothing to explain. They just have different bootloaders because one was manufactured more recently than the other.
The CFE is stored in non-volatile memory but installing a firmware update doesn't normally change it. It's written at manufacturing time.And I believe that the bootloader is part of the software not the hardware.
I have a DSL-AC68U running 384.14 _2-gnuton1 that i have trouble achieving acceptable VDSL2 speeds. It is nothing to do with the firmware, but i loaded it hoping it might address the issue. Using a free cheapie Netcomm modem/router borrowed from my ISP, i can get 22.5- 23 down and just over 1 up out of the box. We are in a rural location about 1.3km from the cabinet hence with the poor numbers, but these are as good as they get.
However, with the DSL-AC68U it is more in the range of 19-20 and 0.8 up and that is after i have maxed it out with tweaks to the DSL connection. Sometimes it will just go slow with single digit download speeds. Reboots and resets do not help. Out of the box, speeds are around 18 down with no tweaks
I have the opportunity to return it under warranty, but that would be a huge hassle time wise (took 2 weeks last time i had a problem) and i don't know if i can expect any better performance if replaced with another. I just don't get why a premium router performs badly with DSL performance, but has such good WiFi capabilities.
Is this a common problem with the 68U and should i expect better from a new unit, in which case i will cut my losses and either get a refund or buy a modem to connect to it and just use Ethernet WAN. I am happy to post my settings & DSL log up if that helps
See this possibly related post https://www.snbforums.com/threads/asus-dsl-ac68u-issue-dropping-connection.61708/#post-549385
Start by examining your SNR and Line Attenuation - if it is poor/bad [see link to acceptable results in referred thread above] - then there isn't a modem/router on the planet that will fix your problem.
The three DSL-AC68U's that I have give the same line speed results in their different locations whether running Asus Stock firmware or GNUton adjusted Merlin firmware.
If your SNR and Line Attenuation results are Good to Excellent at the modem/router - then check with your ISP that you have all the DSL settings correct.
Hi there,@GNUton - now that RMerlin has released 384.15.0 firmware ... it would be really great if you could find the time to update gnuton-ware.
384.15 is incredibly stable and feature rich.![]()
Yours is the first fork that includes amtm. Thanks!Hi there,
I there is a 384.15 pre-release now available for testing.
It can be downloaded from https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/384.15_0-gnuton0_alpha2
It is already running on my router and I'm connected thanks to it.
Please test it out and let me know if you face any problem.
Thanks a lot!
Welcome To SNBForums
