Wow, I just read through the entire thread but I think I am more confused now than when I started
I need advice, can you help Tipstir?
I have pretty simple needs:
I have a 50/50mbps fiberoptic connection, and a home server that runs a lot of P2P (bittorrent) a lot of the time. Ideally I want a router that can handle QoS for the full 50mbps up and down so I can get good performance if i play games or use VoIP even when the server is trying to max out the upstream/downstream with bitorrent traffic.
Other than that I just need a half-decent wireless connection that will not be used very heavily - maybye streaming a few movies over the network now and then. It needs to be pretty stable, but I obviously don't stress them as much as you do in your setup. There is no repeaters or DNS relaying (this 9850 will be the main router connected to the PPPoE directly and DHCPing the rest ofthe network). I only have a single central router for the network and a few clients who occationally use the WLAN mostly for light traffic.
Oh, and I don't want to spend a LOT of money on it...
Thats why the 9850 seems so tempting. Super speed for low cost = win?...
Can the 9850 handle the QoS on such a fast connection? Is this a good idea or should I be looking at some other hardware?
I am pretty technical but I just never worked with networks of your size/complexity, so I dont know if most of the problems you experience will apply for my use. I just need a damn fast router that does good QoS and a decent pretty-stable WLAN for a good price.
Thanks to anyone who can give me advice
Sincerely
-Stigma
PS: I am familiar with DD-WRT and prefer router that have DD-WRT support, but I can get a fast enough QoS router for this low a price then I don't mind too much if the tradeoff is that it might not get DD-WRT support. I am also open to suggestions of other routers.
