Entware Entware
Dear Voxel,
After upgrade unbound to the most recent version (1.13.0) there are issues with accessing domain 'internic.net'.
unbound-host -C /opt/etc/unbound/unbound.conf -v -d internic.net. -t SOA
internic.net. has SOA record sns.dns.icann.org. noc.dns.icann.org. 2020121130 3600 1800 604800 3600 (BOGUS (security failure))
validation failure <internic.net. SOA IN>: No DNSKEY record for key internic.net. while building chain of trust
There are many "Operation not supported" in unbound log before getting above error 'No DNSKEY record'.
Jan 17 22:51:49 libunbound[18715:0] error: tcp sendmsg: Operation not supported for 199.4.138.53 port 53
Jan 17 22:51:49 libunbound[18715:0] error: tcp sendmsg: Operation not supported for 192.82.133.30 port 53
Jan 17 22:51:49 libunbound[18715:0] error: tcp sendmsg: Operation not supported for 192.42.178.30 port 53
Jan 17 22:51:49 libunbound[18715:0] info: Capsforid: timeouts, starting fallback
Jan 17 22:51:49 libunbound[18715:0] error: tcp sendmsg: Operation not supported for 192.42.177.30 port 53
Jan 17 22:51:49 libunbound[18715:0] error: tcp sendmsg: Operation not supported for 202.12.31.53 port 53
Is it possible to get access to previous version(1.11.0) while investigating?
Do you know what problem could be?
There is new feature: "upstream TCP and TLS query reuse".
NLnet Labs - Unbound - Download
Thanks,
It is possible. Usually I keep few previous versions:
So it is possible e.g. to manually download unbound*.ipk and to install them from IPK-file by Entware's opkg. Or to change /opt/etc/opkg.conf to switch completely to previous version of Entware.
Sorry, I don't. I do not use unbound directly.
Good luck,
Voxel.
Hi Voxel,
Is it possible for you to add "php7-pecl-imagick" package?
I needed it for wordpress.
I've passed your request to Entware team. I think it will be possible because "php7-pecl-imagick" is included into OpenWRT packages now:
Voxel.
Good luck,
Voxel.
Thanks Voxel,
I have been able to fix the problem with the unbound 1.13.
It was parameter 'edns-buffer-size' - become default at value '1232' in version 1.12. It was not present in my unbound configuration. At the moment put it to 4096.
Thanks again!
Info for Entware users: my version of Entware is upgraded.
It is enough to run:
/opt/bin/opkg update
/opt/bin/opkg upgrade
to upgrade your version.
Voxel.
Thanks @Voxel. The update/upgrade went smoothly.
It was also great that it detected the nginx config file that I was experimenting with, and did not overwrite it:
Collected errors:
 * resolve_conffiles: Existing conffile /opt/etc/nginx/nginx.conf is different from the conffile in the new package. The new conffile will be placed at /opt/etc/nginx/nginx.conf-opkg.
I will revert to previous version.
It appears that htop does not work properly in latest release (shows no processes), and busybox 1.33.0-1 traceroute is buggy (as reported here: http://forum.tinycorelinux.net/index.php?topic=24849.0 )
Looks like Entware team did not fully check this release...
PS: thanks @Voxel to leave access to previous releases. I downgraded only htop and busybox; works fine.
It is practically impossible for Entware team (3-4 guys as far as I know) to test everything. Currently Entware consists of 2654 packages... Only compilation (4 parallel threads) takes for me about 6-7 hours... Compare with my firmware for R7800: 377 packages compiled during one hour, single thread.
As a rule sources for Entware is OpenWRT GPL. OpenWRT has (well, as far as I know) relatively big amount of developers responsible for such or such project. E.g. busybox: MAINTAINER:=Felix Fietkau <nbd@nbd.name>. htop: MAINTAINER:=Etienne CHAMPETIER <champetier.etienne@gmail.com>. Entware guys could report the issue to OpenWRT but should sync their packages with OpenWRT.
It is me who makes such brave experiments with packages/compilers/tools in my firmware ;-) because I am able to test almost everything. Entware is used in a lot of various gadgets (mips, armv5, armv6, armv7 with kernel 2.6, armv7 with kernet 3.x, x86 etc.) A lot of thanks to these guys.
Voxel.
Voxel.
I get it :)
It seems that the busybox traceroute issue was already reported, but I will double check.
I will check about the htop and report directly to the OpenWRT maintainer for it. Thanks for these precious precisions.
I get it :)
I do not mean that you should report this to maintainers from OpenWRT... It is just a part of Makefiles.
Voxel.
Voxel.
Yes, I see that.
I have contacted Etienne CHAMPETIER who advised to report it in the OpenWRT GitHub under htop package, and from there, he will have a look. He asked me if through Entware I had access to releases 3.0.2, 3.0.3 and 3.0.4, probably to check in which one the problem was introduced. I told him no, but that I can probably compile these versions. We will see.
Thank you again :cool:
Some update:
I was able to build htop 3.0.2 from the official tarball release and it works.
Then I did the same with htop 3.0.3, and it shows the issue.
The problem appeared between versions 3.0.2 and 3.0.3.
I reported this to the OpenWRT issues report for package htop.
To be continued...
Latest news:
Mr CHAMPETIER tried htop on OpenWRT
Hi bolemo
I just tried with a RaspberryPI 2, so cortex A7 but same instructions ARMv7-A and everything work fine with latest OpenWrt snapshot / htop 3.0.5-1
So this issue seems more specific to Entware.
Does anyone else here experience the same bug with latest Entware’s htop?
Ok. solution found for htop:
It needs to be configured with this option: ac_cv_func_openat=no before compilation.
And it works :)
EDIT: Also, I was informed that it is now already fixed in Entware, and they think @Voxel will likely do the same for his next release.
So I was wondering why my wordpress keep complaining that "zip" PHP module is not installed or not enabled.
Today when I run "/opt/bin/php-cgi" command and this is what I found:
Bash:
root@R7800:/tmp/mnt/sda1/entware/share/nginx/html$ /opt/bin/php-cgi
PHP Warning:  PHP Startup: Unable to load dynamic library 'zip.so'
(tried: /opt/lib/php/zip.so (libnettle.so.7: cannot open shared object file: No such file or directory),
/opt/lib/php/zip.so.so (/opt/lib/php/zip.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
I search across the web and found one solution written in Russian:
Bash:
/opt/bin/opkg list-installed|grep -v "libc "|sed 's/ - .*$//'|grep lib|grep -v libpthread|grep -v libgcc|xargs -n 5 /opt/bin/opkg --force-reinstall install
After waited for a while for the packages reinstallation, the "zip" PHP module not install or not enabled issue went away.
