Do they work in tools sysinfo? I shamelessly copied the functions from that page. Maybe the ax88u does something different, I'll check the actual sourceI love the new interface. For me, Router Temperatures are blank on RT-AX88U, 384.19 Merlin -- they are displayed correctly from command line:
Temperatures
CPU: 62°C
2.4 GHz: 46°C
5 GHz: 44°C
@visortgw please uf and try again. Hopefully fixed https://github.com/jackyaz/scMerlin/commit/69b9cdb9a238b077a4a61071581df0ec83095544Do they work in tools sysinfo? I shamelessly copied the functions from that page. Maybe the ax88u does something different, I'll check the actual source
That fixed it! Thanks.@visortgw please uf and try again. Hopefully fixed https://github.com/jackyaz/scMerlin/commit/69b9cdb9a238b077a4a61071581df0ec83095544
The latest scmerlin Web does look great! Like the Restart tabs.
One idea - just a thought.
As you said before, the Memory and Internal Storage are very similar to Merlins Tool page.
I'm a graphical kind of person. How about Pie charts for both? A picture tells a 1000 words ;-)
I'm weighing up removing those 2 options from scmerlin. I don't think it's correct for my script to interfere with other scripts like that.Just updated again - and WOW ... really useful additions - well done @Jack Yaz .
Pretty much covered everything in the scmerlin text menu - except disable Diversion / and disable skynet.
After deciding on how to proceed with this, i think I'm feature complete for v2 and I'll look to release it in a few days.@Jack Yaz now that those scripts have their own router GUI's, I would tend to agree with this.
And even though Skynet doesn't have a 'disable' button in the GUI, it has never caused me or any customer any issues at all to need to disable it.
AWESOME work! Thanks.After deciding on how to proceed with this, i think I'm feature complete for v2 and I'll look to release it in a few days.
happy to hear thatExceeded my epxectations by a wide margin! This will make make monitoring memory/nvram usage so much easier. Great job!
For those using the "developers" script...will it be a simple U /UF update to the official release? Thanks again for everything!PR is up for v2 so no more updates to watch for on develop
I aim to release by end of Wednesday unless anything showstopping gets found
it should be, yes!For those using the "developers" script...will it be a simple U /UF update to the official release? Thanks again for everything!
Welcome To SNBForums
