johnathonm
I can't seem to get it to install even after completely wiping the router, reinstalling the firmware etc.
Info: This platform supports both 64bit and 32bit Entware installations.
Info: 64bit support is recommended, but 32bit support may be required
Info: if you are using other 32bit applications.
Info: The 64bit installation is also better optimized for newer kernels.
=> Do you wish to install the 64bit version? (y/n) y
Info: Installing the 64bit version.
Info: Looking for available partitions...
[1] --> /tmp/mnt/poop
=> Please enter partition number or 0 to exit
[0-1]: 1
Info: /tmp/mnt/poop selected.
Info: Creating /tmp/mnt/poop/entware folder...
* Warning: Deleting old /tmp/opt symlink...
Info: Creating /tmp/opt symlink...
Info: Creating /jffs scripts backup...
tar: removing leading '/' from member names
Info: Modifying start scripts...
johnathonm@RT-AC86U-2B48:/tmp/home/root# opkg
-sh: opkg: not found
Any ideas because I got nothin
[0-1]: 1
