FlexQoS FlexQoS 1.4.4 - Flexible QoS Enhancement Script for Adaptive QoS
can i install flexqos with the official firmware? Thanks
Back in the day when Flex was FreshJR_QoS there was an option to manually install it on stock firmware. I'm sure there still might be away but maybe someone else can assist further!
Look at alternate (manual) install link below and it will require a USB (flash drive) connected at all times:
Post in thread '[Release] FreshJR Adaptive QOS (Improvements / Custom Rules / and Inner workings)' https://www.snbforums.com/threads/r...om-rules-and-inner-workings.36836/post-301766
Something quite particular to PS5 results in the game downloads iptable spiking a core and being limited to 300Mb/s
Can't replicate this with PC's or Xbox.
Are you still having this issue? Can you provide some pics of setup and what you're seeing?
It's a stock install of flex qos, set to the default fqs_codel, with adaptive qos set to 800/44
both the ps5 network test and game downloads cap out at 30ishMB/s(300mbit) with the router spiking either core 1 or core 4 at 100%
The ps5 opens so many connections at once it dosses the thing from within lmao
I've actually seen this being shown in quite a few "make ps5 download faster" videos, where they go from 50-100mbit to 300 by changing the DNS setting, and i'm sure many of these cases have users with faster internet than that, so it seems to be an across the board issue with some QoS methods.
So with QoS disable, do you still notice the download limit or only with QoS enabled?
I did see quite a few post about PS5 download speeds (when downloading from PS5) being limited due to various reason but possibly being throttle by Sony servers depending on time of day due to serve load.
I don't see the contention until FlexQoS applies "Game Downloads"
787Mbit/s download
What router is this? Is the Flow Cache Control option visible in FlexQoS, and if so, is it enabled?
Otherwise, what’s the output of fcctl status command?
AX88U, yes it is.
        Flow Timer Interval = 10000 millisecs
        Pkt-HW Activate Deferral rate = 1
        Pkt-HW Idle Deactivate = 0
        Pkt-SW Activate Deferral count = 0
        Acceleration Mode: <L2 & L3>
        MCast Learning <Disabled>
        MCast Acceleration IPv4<Enabled> IPv6<Enabled>
        IPv6 Learning <Enabled>
        GRE Learning <Enabled> Mode<Tunnel>
        4o6 Fragmentation <Enabled>
        TCP Ack Prioritization <Enabled>
        HW Acceleration <Enabled>
        Flow Learning Enabled : Max<16384>, Active<145>, Cummulative [ 164556 - 164411 ]
AX88U, yes it is.
Is your Flow Cache mode set to Auto or Off? Try to set it to 'On' and test your setup again. Flow learning should be disabled for newer routers (AX). This is how my setup looks:
ASUSWRT-Merlin GT-AX11000_PRO 3004.388.8_4 Sun Nov 17 19:18:02 UTC 2024
XXXX@GT-AX11000_Pro-XXXX:/tmp/home/root# fcctl status
        Flow Low Pkt Rate = 10
        L2TP Learning <Enabled>
        ToS Multi Flow <Enabled>
        Notify Processing Mode <Hybrid>
        OVS Flow Learning <Disabled>
        Flow Ucast Learning Disabled  : Max<16383>, Active<0>, Cumulative [ 145 - 145 ]
        Flow Mcast Learning Disabled  : Max<1152>, Active<0>, Cumulative [ 0 - 0 ]
Are you planning to adapt it for BE88U and 3006.102.3 firmware?
@Kingp1n
why does it show 1 thing disabled
Flow Ucast Learning Enabled : Max<16383>, Active<208>, Cumulative [ 554 116 - 553908 ]
Flow Mcast Learning Enabled : Max<1152>, Active<0>, Cumulative [ 0 - 0 ]
robinjoo1@GT-AX11000_Pro-0950:/tmp/home/root#
@Kingp1n
Would you be able to share a screenshot of your Flex QoS tab after you hit the Customize option?
I have Flow Cache (FC) mode set to 'Auto' and since I use iptable rules which automatically disables Flow Cache. You can see this under Tools --> Network.
Also please check bottom of GUI screen under Tools --> Network. How does your HW Acceleration is showing. Mine has 'Runner' enabled and 'FC' disabled.
oh i dont use the tool i was merly curious why it has this output
but it hass to do with hardware offloading cause if i disable it i lose speed
