I'm finding v13 solid on the RT-AC68P as well. No disconnects or reboots required, wireless is as good as previously for me.
Thanks very much!
absolutely.im on the rt-ac68u. what logs do you want?
edit: heres the syslog
There's several errors related to running Transmission....for some people it works, others not. Try turning that off and see if things improve.
Also, I believe Transmission 2.84 is available via Entware....you may want to try updating if running without it enabled stabilizes things.
strange... I didn't even know transmission was a possibility, and Im 99.9% certain ive never turned it on. Can you point me towards the setting for that, im not seeing it...
edit; OK I've been through every setting, and I dont see it, and I know I've never installed transmission on this hardware.
Hi, just wanted to ask if SNMP is included in the AC68U build?
Tried to search the forum and found that the "original" build seems to include this.
You never installed Entware/Optware? I'm definitely not an expert on Transmission, but it may also be installed as part of Download Master.
SNMP was added after the code on which the fork is based was released. Sorry, but no plans to add it.
no, never installed anything like that. download master was installed, but I disabled it yesterday, but still woke up this morning, like every morning since 13e1, and had to reboot the router because it had stalled. this time I had to physically reboot it because I couldn't even connect to it at 192.168.1.1
edit: all i want to backup settings wise is the manual dhcp server settings and port forwarding, that way i can reset the vram and start new. will the restore/save option in administration pull a lot more than that?
sure. The whole idea behind this fork is that John will create updates so the components used by this firmware will get security updates. So from security point of view it is worth to update.
Ive had to manually reboot the router about once a day for past two builds because of losing internet access. V11 would last for weeks, but these past two havent so much. No special vpn or anything like that being used, only have a usb drive attached.
Same problem here. No connection via wireless possible with lates version (v13), had to reboot after updating to V13. I had no issues with RT-N66U_3.0.0.4_374.43_2-11E1j9527.trx
Maybe someone can check my log file? (MACs have been removed) RT N66U losing connection to internet and or to wifi in general. After reboot everything is fine for a while.
And of course: THANK YOU John and Merlin. Your firmwares are freaking awesome!! I love it.
Jul 26 12:33:56 rc_service: ntp 476:notify_rc restart_upnp
Jul 26 12:33:56 miniupnpd[475]: shutting down MiniUPnPd
Jul 26 12:33:56 miniupnpd[485]: HTTP listening on port 45720
Jul 26 12:33:56 miniupnpd[485]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 26 12:33:56 rc_service: ntp 476:notify_rc restart_rdnssd
Jul 26 12:33:56 rdnssd[430]: Child process hung up unexpectedly, aborting
Jul 26 12:33:56 rc_service: ntp 476:notify_rc restart_diskmon
Jul 26 12:33:56 disk monitor: be idle
Jul 26 12:33:59 dnsmasq-dhcp[317]: DHCPDISCOVER(br0) 6c:ad:f8:51:bc:
Jul 26 12:33:59 dnsmasq-dhcp[317]: DHCPOFFER(br0) 192.168.1.154 6c:a
Jul 26 12:33:59 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.143 ac:2
Jul 26 12:33:59 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.143 ac:22:0
Jul 26 12:34:03 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.154 6c:
Jul 26 12:34:03 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.154 6c
Jul 26 12:34:31 nmbd[364]: [2015/07/26 12:34:31, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jul 26 12:34:31 nmbd[364]:   Samba name server RT-N66U-44D8 is now a local master browser for workgroup SDASDASD on subnet 192.168.1.1
Jul 26 12:34:35 crond[320]: time disparity of 2401114 minutes detected
Jul 26 12:34:41 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.74 c8:
Jul 26 12:34:41 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.74 c8:bc:c8
Jul 26 12:34:56 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.158 10
Jul 26 12:34:56 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.158 10:bf
Jul 26 12:36:20 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.230 e0:
Jul 26 12:36:20 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.230 e0:b5
Jul 26 12:38:13 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.245 e8:
Jul 26 12:38:13 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.245 e8:
Jul 26 12:40:40 rdnssd[488]: Get IPv6 address & DNS from DHCPv6
Jul 26 12:40:40 rc_service: rc 498:notify_rc start_dhcp6c
Jul 26 12:40:41 dnsmasq[317]: read /etc/hosts - 6 addresses
Jul 26 12:40:41 dnsmasq[317]: read /etc/hosts.dnsmasq - 4 addresses
Jul 26 12:40:41 dnsmasq-dhcp[317]: read /etc/ethers - 4 addresses
Jul 26 12:40:41 dnsmasq[317]: using nameserver 192.168.178.1#53
Jul 26 12:40:41 rc_service: dhcp6c-state 502:notify_rc start_radvd
Jul 26 12:40:41 rc_service: dhcp6c-state 502:notify_rc start_httpd
Jul 26 12:40:41 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 12:40:41 radvd[503]: version 1.15 started
Jul 26 12:40:42 RT-N66U: start httpd
Jul 26 13:10:42 rc_service: dhcp6c-state 512:notify_rc start_radvd
Jul 26 13:10:42 radvd[507]: Exiting, sigterm or sigint received.
Jul 26 13:10:42 radvd[507]: sending stop adverts
Jul 26 13:10:42 radvd[507]: removing /var/run/radvd.pid
Jul 26 13:10:42 radvd[513]: version 1.15 started
Jul 26 13:10:42 rc_service: dhcp6c-state 512:notify_rc start_httpd
Jul 26 13:10:42 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 13:28:42 radvd[528]: removing /var/run/radvd.pid
Jul 26 13:28:42 radvd[533]: version 1.15 started
Jul 26 13:28:43 RT-N66U: start httpd
Jul 26 17:40:44 rc_service: dhcp6c-state 662:notify_rc start_radvd
Jul 26 17:40:44 rc_service: dhcp6c-state 662:notify_rc start_httpd
Jul 26 17:40:44 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 17:40:44 radvd[655]: Exiting, sigterm or sigint received.
Jul 26 17:40:44 radvd[655]: sending stop adverts
Jul 26 17:40:44 radvd[655]: removing /var/run/radvd.pid
Jul 26 17:40:44 radvd[663]: version 1.15 started
Jul 26 17:40:45 RT-N66U: start httpd
Jul 26 18:10:45 rc_service: dhcp6c-state 673:notify_rc start_radvd
Jul 26 18:10:45 radvd[667]: Exiting, sigterm or sigint received.
Jul 26 18:10:45 radvd[667]: sending stop adverts
Jul 26 18:10:45 radvd[667]: removing /var/run/radvd.pid
Jul 26 18:10:45 radvd[674]: version 1.15 started
Jul 26 18:10:45 rc_service: dhcp6c-state 673:notify_rc start_httpd
Jul 26 18:10:45 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 18:10:46 RT-N66U: start httpd
Jul 26 18:40:45 rc_service: dhcp6c-state 687:notify_rc start_radvd
Jul 26 18:40:45 radvd[678]: Exiting, sigterm or sigint received.
Jul 26 18:40:45 radvd[678]: sending stop adverts
Jul 26 18:40:45 radvd[678]: removing /var/run/radvd.pid
Jul 26 18:40:45 radvd[688]: version 1.15 started
Jul 26 18:40:45 rc_service: dhcp6c-state 687:notify_rc start_httpd
Jul 26 18:40:45 RT-N66U: start httpd
Jul 26 19:08:17 dnsmasq-dhcp[317]: DHCPDISCOVER(br0) e8:50:8b:a6:cd:6e
Jul 26 19:08:17 dnsmasq-dhcp[317]: DHCPOFFER(br0) 192.168.1.245 e8:
Jul 26 19:08:48 dnsmasq-dhcp[317]: DHCPDISCOVER(br0) e8:
Jul 26 19:08:48 dnsmasq-dhcp[317]: DHCPOFFER(br0) 192.168.1.245 e8:
Jul 26 19:08:48 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.245 e8:
Jul 26 19:08:48 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.245 e8:5
Jul 26 19:08:49 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.245 e8:
Jul 26 19:08:49 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.245 e8:
Jul 26 19:10:45 rc_service: dhcp6c-state 697:notify_rc start_radvd
Jul 26 19:10:45 rc_service: dhcp6c-state 697:notify_rc start_httpd
Jul 26 19:10:45 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 19:10:45 radvd[693]: Exiting, sigterm or sigint received.
Jul 26 19:10:45 radvd[693]: sending stop adverts
Jul 26 19:10:45 radvd[693]: removing /var/run/radvd.pid
Jul 26 19:10:45 radvd[698]: version 1.15 started
Jul 26 19:10:46 RT-N66U: start httpd
Jul 26 19:31:11 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.143 ac:22:
Jul 26 19:31:11 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.143 ac:22:0
Jul 26 19:40:46 rc_service: dhcp6c-state 711:notify_rc start_radvd
Jul 26 19:40:46 radvd[705]: Exiting, sigterm or sigint received.
Jul 26 19:40:46 radvd[705]: sending stop adverts
Jul 26 19:40:46 radvd[705]: removing /var/run/radvd.pid
Jul 26 19:40:46 radvd[712]: version 1.15 started
Jul 26 19:40:46 rc_service: dhcp6c-state 711:notify_rc start_httpd
Jul 26 19:40:46 rc_service: waiting "start_radvd" via dhcp6c-state ...
Jul 26 19:40:47 RT-N66U: start httpd
Jul 26 19:44:47 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.154 6c
Jul 26 19:44:47 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.154 6c:ad:
Jul 26 19:45:05 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.247 a0:0b
Jul 26 19:45:05 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.247 a
Jul 26 19:45:08 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.24
Jul 26 19:45:08 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.24
Jul 26 19:45:23 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1
Jul 26 19:45:23 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.
Jul 26 19:46:38 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.1.74
Jul 26 19:46:38 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.74 c
Jul 26 20:02:04 dnsmasq-dhcp[317]: DHCPREQUEST(br0) 192.168.
Jul 26 20:02:04 dnsmasq-dhcp[317]: DHCPACK(br0) 192.168.1.230 e0:b
Jul 26 20:13:53 HTTP login: login 'EFWEFWEF' successful from 192.168.1.178
//edit:
just came back to v11 and wireless internet seems to be much faster as well :( Tomorrow i will do a factory reset before upgrading to v13 and after upgrading. I will let you know
You are cycling trying to set up your IPv6 connection.
Two questions for you...
What type of connection, PPPoE or native?
Location (could you possibly be in UK or Romania?)
Double check your IPv6 settings and try 'unchecking' the Enable IPv6 MTU Advertisement setting on the IPv6 page. (especially if you are PPPoE)
After a firmware updated, content in /jiffs are gone.
I tried to add back user scripts manually, but system returned "read-only file system".
After a firmware update, content in /jiffs are gone.
The jffs space on MIPS routers is shared with the code (uses whatever space is left over after the code load). Hence, that nice yellow WARNING text on the upgrade page about backing up your jffs. You need to disable jffs, reboot, and then re-enable and format, then restore your backup.
Ok John- I have another idea for the firmware. I have been using the custom configuration area to type in some openvpn settings. The problem is, the cursor is pretty much impossible to see (ok, maybe an overstatement there). It may be my browser or something, but if the visibility of the cursor is low for a lot of users maybe it would be a good idea to make it more visible? Maybe thicken it by a few pixels?
The browser draws the cursor, not the firmware...
This one I agree with.....now to start doing some searches to try and learn if its possible (and how to do it..my html is self-taught :) )
I think it's just the Windows default.
You can change the system-wide setting from Control Panel > Ease of Access Center > Make the computer easier to see > Set the thickness of the blinking cursor. That's for Windows 7, in XP it's under Accessiblity Options > Display.
If you're referring to the mouse pointer cursor (the I-beam) that can be changed as well from control panel to an "outlined" shape. (PuTTY has this problem when use over RDP)
Well, of course RMerlin is right again :) In this context, it's not referred to as the cursor, but as the 'caret'...and you basically have no control over it (you can play some games with the background color to try and change the caret color, but that's about it).
You can change the system-wide setting from Control Panel > Ease of Access Center > Make the computer easier to use > Set the thickness of the blinking cursor. That's for Windows 7,
Colin - nice find....I've made use of some of the Accessibility options before, but missed this one. I've been resetting my systems to a 2 pixel width.
@john9527 Don't know if you got my PM but I would like to thank you very much for fixing IPV6. Didn't even realise you did it until I checked the thread again. Great job!
