Well Cox just enabled native IPv6 in my area and it appears working fine. I did notice a problem with QOS with IPv6. With QOS enabled the download is capped with the upload setting. I have 50/5 service and Comcast's speed test shows 50/5 for IPv4 and 5/5 for IPv6. When I disable QOS IPv4 and IPv6 test results are both 50/5. I think this was reported before and was supposed to be fixed in some release.
Forgot to mention I am running version 14E1 of John's fork on a AC-68P
Yes, it should be fixed...I'm on Cox also but use HETunnel for IPv6 (I'm not native enabled yet).
Just double checked with Xfinity speedtest and it's still fine for me.
Can you check the following via telnet/ssh?
nvram show | grep ipv6_prefix
do ipv6_prefix and ipv6_prefix_length look correct (not the ones ending in _s)
QOS previously worked fine with 6to4 tunnel
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Thu Sep 17 09:01:11 UTC 2015
admin@Readyshare:/tmp/home/root# nvram show | grep ipv6_prefix
ipv6_prefix=2600:8800:a880:14::
ipv6_prefix_length=64
ipv6_prefix_s=
size: 47295 bytes (18241 left)
ipv6_prefix_length_s=64
ipv6_prefix_len_wan=64
ipv6_prefix_s=
Looks reasonable/expected.....
Can you try this....
ip6tables - t mangle -L -v
Readyshare login: admin
Password:
ipv6_prefix_s=
admin@Readyshare:/tmp/home/root# ip6tables - t mangle -L -v
Bad argument `-'
Try `ip6tables -h' or 'ip6tables --help' for more information.
admin@Readyshare:/tmp/home/root# ip6tables -t mangle -L -v
Chain PREROUTING (policy ACCEPT 17380 packets, 4489K bytes)
pkts bytes target prot opt in out source destination
6 432 DROP ipv6-icmp eth0 any anywhere ff02::1:
ff00:0/104 ipv6-icmp neighbour-solicitation
Chain INPUT (policy ACCEPT 1758 packets, 157K bytes)
Chain FORWARD (policy ACCEPT 15471 packets, 4313K bytes)
Chain OUTPUT (policy ACCEPT 945 packets, 98419 bytes)
Chain POSTROUTING (policy ACCEPT 17053 packets, 4488K bytes)
PS I do have the qos_sfql set to 1 in NVRAM if that makes a difference
@kolodzij
Now we're getting somewhere.....the ip6tables output doesn't look right
Sorry, but now I need the output of
cat /tmp/mangle_rules_ipv6
@kolodzij
admin@Readyshare:/tmp# ls
@kolodzij
Beceem_firmware ipv6_client_list share
avahi ipv6_neigh syscmd.log
ddns.cache mnt syslog.log
dhtest.txt nat_rules udhcpc
etc nat_rules_eth0_eth0 udhcpc0.expires
filter.default notify usb.log
filter_rules ppp usb_err
filter_rules_ipv6 redirect_rules var
home resolv.conf wpa_cli
ipv6_client_info settings zcip
Sorry, is QOS enabled? It has to be on to generate the files and rules.
Just re-enabled QOS
Password:
admin@Readyshare:/tmp/home/root# cat /tmp/mangle_rules_ipv6
*mangle
:PREROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:QOSO - [0:0]
-A QOSO -j CONNMARK --restore-mark --mask 0x7
-A QOSO -m connmark ! --mark 0/0xff00 -j RETURN
-A QOSO -p tcp --dport 80 -m connbytes --connbytes 0:524287 --connbytes-dir both --connbytes-mode bytes -j CONNMARK --set-return 0x1/0x7
-A QOSO -p tcp --dport 80 -m connbytes --connbytes 0:524287 --connbytes-dir both --connbytes-mode bytes -j RETURN
-A QOSO -p tcp --dport 443 -m connbytes --connbytes 0:524287 --connbytes-dir both --connbytes-mode bytes -j CONNMARK --set-return 0x1/0x7
-A QOSO -p tcp --dport 443 -m connbytes --connbytes 0:524287 --connbytes-dir both --connbytes-mode bytes -j RETURN
-A QOSO -p tcp --dport 80 -m connbytes --connbytes 524288: --connbytes-dir both --connbytes-mode bytes -j CONNMARK --set-return 0x4/0x7
-A QOSO -p tcp --dport 80 -m connbytes --connbytes 524288: --connbytes-dir both --connbytes-mode bytes -j RETURN
-A QOSO -p tcp --dport 443 -m connbytes --connbytes 524288: --connbytes-dir bot
-A QOSO -m mac --mac-source 00:18:61:26:8f:23 -j CONNMARK --set-return 0x1/0x7
-A QOSO -m mac --mac-source 00:18:61:26:8f:23 -j RETURN
-A QOSO -d ff00::/8 -j CONNMARK --set-return 0x6/0x7
-A QOSO -d ff00::/8 -j RETURN
-A QOSO -d /64 -j CONNMARK --set-return 0x6/0x7
-A QOSO -d /64 -j RETURN
-A POSTROUTING -o br0 -j QOSO
-A QOSO -j CONNMARK --set-return 0x4/0x7
-A FORWARD -o eth0 -j QOSO
-A OUTPUT -o eth0 -j QOSO
-A QOSO -j RETURN
-A PREROUTING -i eth0 -j CONNMARK --restore-mark --mask 0x7
COMMIT
****QOS disabled
Password:
size: 47294 bytes (18242 left)
ipv6_prefix_s=
***QOS enabled
Password:
ipv6_prefix_s=
Don't ask me how it corrected itself...but here is the most recent speedtest with QOS on. QOS is set for 45/5 Mb/s. I did not power off or reboot the router!
Maybe it took a QOS off/QOS on cycle since QOS was previously on with a 6to4 relay setting before the native IPv6 today.
I think you have hit upon it. It looks like they replaced a reboot with another set of restarts for the ARM based routers when changing IPv6 types....but it's not obvious it's causing a proper restart of qos. I'll queue this one up for a future release. In the meantime, a reboot after changing IPv6 types should clear things up.
OK I have done a little more research on this and believe there is still a problem with QOS and native IPv6. I have verified this with multiple sites and it only occurs on lan connections, wireless connections QOS work fine. A post from 4/28/2014 on the ASUS RT68U support forum outlines the identical problem.
The following are a wired gigabit lan connection to a RT-68P
QOS ON -native IPv6
QOS OFF - native IPv6
Same wired lan connection with 6to4 and QOS ON
that is very odd, if ipv6 QoS was broken I expect the result would be QoS not working rather than a very small speed. Sadly I dont have native ipv6 currently so cannot test it but when I did have it some months ago I dont recall having this issue.
@kolodzij
I've been thinking about this since I saw your post, and have a new hypothesis. The fix I applied was tested by other native users so I know the fix works.
The data you had previously posted showed that the IPv6 prefix value was set both before and after starting QOS, but the QOS startup couldn't read the prefix from nvram. The exact same code is used independent of the IPv6 mode, so I don't think there is any problem there.
Now, turning on QOS causes a reboot (I think to make sure CTF is set properly) and the QOS rules are actually generated early in the reboot process. So my guess is that while Cox may have enabled native IPv6, they are slow in setting it up, and when the QOS rules are set, IPv6 isn't fully up and the QOS rule generation has no prefix to read.
For a test, when QOS is already on and you have the problem go to the main QOS page and slightly change either the upload or download bandwidth setting and hit Save (I think you may not even have to change anything before hitting Save, but let's play it safe). This will regenerate the QOS rules and restart QOS without causing a restart of IPv6. I'm betting this will correct things..
@kolodzij
Nope, still no go on Lan ports, IPv6 QOS works fine on wireless, that's the part that puzzles me. I have uploaded the system log after I modified the QOS speeds followed by a reboot. BTW I have verified this on 2 separate machines.
PS When I modified and saved the QOS parameters I lost IPv6 connectivity and had to restart
so perhaps your theory is still possible.
