Holy crap Tim, that is some serious cooling.
Isn't the noise driving you crazy?
Edit:
To answer your questions.
We use this fork because it's the latest that lets you play with regional settings.
That means you have the freedom to use the RF channels you want and output power you want.
(Within your local government WiFi rules of course.)
John takes care of this fork to make sure it has the latest security patches.
So no, no 500mW from the latest firmware. (ASUS or RMerlin.)
If I remember correctly it's stuck at max. 100mW.
The Noise is none. Because of the Fan's are on low speed i think 500rpm.
Does the update's 1, 2 and 3 have anything todo with the max output?
Because i think (almost know for sure) that after a update i dont have the 500 mw anymore. Even with the commands i dont see any my output like i seen without the updates on this Fork.
But then again i'm new with this router its like 4/5 days ago i have bought it in the shop. So maybe i do something wrong? because i have heard also about reboot after the commando's? but dont know for sure...
I also installed snmp on it and now i can see all dev, interfaces, and temps with zabbix.
Well maybe someone willing to explain howto get 500mw. And what are the best antennes for this router?
I have seen some i build years ago, its from a cabel made. Dont know the name, but maybe some know some cheap antennes that are better then those on it now..
Thx
Tim
