John got some feedback from a sky customer who switched to your firmware from shibby, on sky uk isp and using the ac68.
He said it all is working so far with ipv6. I dont know if he is using 19E1 or 19E2. :)
John, I have a launch model AC68U with 1.0.2.1 and either 18E1 or 18E3 on it, it has never had any variety of 19. Would it be beneficial for you for me to update it?
To anyone willing to help out who is having problems updating on an AC68
I've uploaded a V19X3 trx to the beta download directory
Download http://bit.ly/1UGjcOX
This completely removes all the changes for the added IPTV profiles. Unfortunately, we're down to the process of elimination.
Thanks in advance.
Thanks for the feedback.....I needed some good news today :)
John,
I was able to directly upgrade from 18E3 to 19X3 with no difficulty. (I was one who had not been able to upgrade to V19.)
Looks like you're on the trail! Let me know if you need any syslogs.
Thanks.
@Pat57 - Only one thing to say...
At least I know where to look now. And thanks to @M1ch43lk for helping to narrow the scope.
Thanks in advance.
Thanks, Will try it out when I'm back home. Yesterday I was doing the upgrade remotely and lost the connection ;)
I noticed that in some of the other posts people are having newer versions of the bootloader... Is there a simple way to just update the bootloader? Or do I have to update to some newer ASUS original image and then back to this fork? Which is the latest bootloader version for RT-AC68U? Advantages of newer bootloader?
Thanks....I'm getting a V19E3 build ready to post that temporarily removes the IPTV updates. If I could get another data point that that indeed fixes the problem it would be great.
There are ways to update the bootloader via CLI, but playing with the bootloader and having a problem is one way to truly 'brick' the router. For the ARM routers, you want to be on a 1.0.2.x level. That enables 64M rootfs support which gives you the flexibility to load any code you want., and in most cases allows overclocking of the memory. From my point of view, it's safest to do it with one of the ASUS OEM builds, which I have in the download directory, or Merlin build 380.55 (the code has to be small enough to still fit in a 32M space). They don't document bootloader changes, so don't know what may be changing, except for the couple of things I noted above. AFAIK, ASUS hasn't forced any bootloader updates except for the 1.0.1 to 1.0.2 update.
I'd be happy to flash it. Can I flash it directly over V19E1 without clearing nvram?
FYI: Just upgraded successfully from 18E3 to 19X3 :)
Have only been running a few minutes but first impression is that things are working fine.
Sorry for the recent code churn.....
Thanks to @Pat57, @M1ch43lk, @InkyRag I was able to isolate the update failures to V19 to the new support for additional IPTV profiles. While I review that code, I have created an update V19E3 which temporarily removes that support. Since I don't yet understand the failure mechanism, and why some experienced problems and not others, I would recommended scheduling an update to the V19E3 firmware for anyone running a previous V19 level.
LATEST RELEASE: Update-19E3
12-September-2016
Merlin fork 374.43_2-19E3j9527
Download http://bit.ly/1YdgUcP
Update-19E3 Highlights (full changelog is in the zip files)
  • Temporarily remove support for additional IPTV profiles as it was causing failures during firmware update for some users
  • Update link to new firmware on firmware update page - @Santiago C
SHA256
715160b0b49fce44d60120bb1c4c68ed0db8cd8f35119a16ba5a557c319e2e47  RT-AC68U_3.0.0.4_374.43_2-19E3j9527.trx
f0d9a4e248d298953c15beff8fba3a8b58ed2f4d42b4c2d23378c8161044adbf  RT-AC56U_3.0.0.4_374.43_2-19E3j9527.trx
b3ab639931abace919c788032888ae7193a9e03793f724e9245fcfbca4f7a9a4  RT-N16_3.0.0.4_374.43_2-19E3j9527.trx
deb3434be7d017dc1ddbde801f20e92c889ef2ee3f51aea8498f05b0cd000fcd  RT-AC66U_3.0.0.4_374.43_2-19E3j9527.trx
6214f24c3c67ea51a1b6e43ff6296e4f431fc2ca1364b2b109971896224b191e  RT-N66U_3.0.0.4_374.43_2-19E3j9527.trx
Was on 14e2 on 68R with old bootloader.
Updated the bootloader. Manually rebooted.
Updated to 19E3. Manually rebooted.
Looking fine. No settings lost. I didn't do any resets.
Huge thanks to Merlin and John for these magnificent firmware's!
RT-AC56U CFE 1.0.1.9 and upgraded to 1.0.2.9 because V19E1 caused problems
Coming from V18E3 and erased nvram and loaded V19E2. Had to reset router after that. Then manually entered configuration. Started at "General" and worked my way down. At about "LAN" the thing locked up and had to reset. Started at the bottom and worked up and it locked up again. Reset and recovered.
Flashed V19E3. Zero problems manually configuring. Running like a champ.
@john9527 I think you found the reasons for the lock ups. Appears the CFE didn't matter. Thank you for your help over the weekend.
I have two asus rt-n66u running the latest merlin fork.
How do I simply enable bandwidth limiting (either via web gui or ssh) for the main 5GHz Asus SSID (wl1)?
I tried enabling the QoS - Bandwidth Limiter as per John9527's advice here but no dice (my imgur screenshots below):
  • Yes sir....enabled for the N66U as well (enabled for all the fork supported routers until someone tells me it doesn't work and I find out I can't fix it :) ) As far as bw limits for the guest networks (wl1.1), the code is there, but I haven't tested that one yet. Just enter the interface name for the guest network in the target field where you would put the mac/ip address (i.e. wl0.1 for 2.4GHz Guest 1, wl1.1 for 5GHz Guest 1, etc.). If you try it, please give feedback.
  • http://i.imgur.com/8jf8gUy.png
  • http://i.imgur.com/szmdCe9.png
A few other posts I found in regards, I've been searching and searching and trying and trying to no avail... :(
Hopefully someone can chime in and save me some grief... Must sleep now (becoming part of the furniture isn't easy)!
Thanks y'all!
