Unfortunately for me the new firmware wouldn't allow my Kindle to access the network all the time
Managed to use the User NVRAM Save/Restore Utility Beta and it works like a charm..Thanks, John!
Hi there!
I apologize, but I'm not sure where you ended up....Is everything now OK on the lastest level or is there something I can try to help out with?
Just checked my N66U and its set to off it must be befault because i never touched it.
For 'US' routers it will default to off. If 'EU' it will change to 802.11d+h
The code tries to walk the line between staying regulation compliant (right up to the limits) in it's default state, while still allowing someone who really wants to go outside the limits to do so by manually adjusting some of the nvram settings.
Nvram Save/Restore Beta Utility (Rocks)!
Wow! That's a really quick reply,John. I ended up switching over to 376.49_5 and all is well. I just don't really understand the Kindle connect issue and certainly hope that I'm the only one.
The Beta Utility you put together saves so much time, if you need to switch back and forth on firmware settings.
I'm thinking that there might just be some sort of glitch in my specific environment.
@cofetym - I try to keep a little closer eye out right after I release a new code in case I made an 'oops':)
Sorry about the Kindle problem....if you decide to try again with the fork, let me know.
Working fine here. VPN speeds are over 40Mbps. I forget what it was before. Haven't used it in a while. When I use VPN, my VOIP does not work. It there some way to fix that?
I have an Obi 200.
I have an Obi 200.
Most of those VOIP boxes work by setting up there own VPN-like connection, so don't work if being routed through another VPN. The way around that is to exclude the ip of the VOIP box from using the VPN. If you do a search on 'Selective Routing' in this forum you'll find some script templates on how to set that up.
Would it be ok to use a network switch. Connect the modem to switch, one cable to Obi and one to router?.
Upgraded my RT-N66 today to V7 of the fork and everything working great!
Have a Kindle and having no problems with the new release.
Hey John been over 24 hours now with V-7 and i have had no issues what so ever seems rock solid as of now. :)
@john9527, may I please mirror your files? If needed, I will happily give you full access to file management. It's my first time trying your firmware fork and was observing the Microsoft OneDrive hosting is slower than I'm accustomed to, reaching no more than 500-600 Kbps. I would also like to help others download the files faster. :)
The issue with my Kindle was on the RT-AC66U router:confused:
I will try again when the Family doesn't need access to the internet.:D
Dont you just hate when you want to play with your network but family is using it.. Ugg !! :(
Excellent job, John. Version 7 rock solid so far. Not sure if it is just fork update placebo effect but I notice it seems to reconnect faster when I wake my computers.
Are you using comcrap for your ISP ?
Yes, Comcrap and I have seen the same IPv6 delays previously on reboot, but this time I updated my two routers and suspect the main N66 already pulled the IPv6 address before I tested since the AC66 was updating thereafter for ~3min.
I always seem to be messing with the internet when my kids are doing something important.:D:D:D
Not sure what changed in your last update, but my webpages now load much faster, even when youtube is being hammered at peak hours.
Saw an instant change right after flashing with v7 firmware.
Same here. Link speed is the same as before but pages definitely load faster. Most noticeable on pages with loads of images or graphic/video elements.
I always thought the slowness before was just Firefox being bogged down and laggy as it tends to be from time to time. No noticeable page load speed difference between all previous firmware versions.
Noticeable improvement now on both ipv4 and ipv6 sites.
Weird. Nice...but weird.
Local LAN file copying speeds don't seem to be affected compared to previous versions.
I was using the Beta 7 fork build and just switched the official fork 7 build.
Comcast here as well.
I noticed with both beta and offical build that the IPv6 clients took a few minutes to get an address - but after that it seems fine.
I have also been using a changed administrator name for at least a year with both Merlin and now the fork with no IPV6 issues.
I enabled the Comcast DSCP fix in both the beta and official release - hard to tell if it made a difference - maybe pages are loading a little quicker but hard to tell.
The 7 release does seem stable and works well for me and continues to give me better WiFi range the latest Merlin releases.
There was no need to add the fix in the final build as all this was already done hence final release.
If you did that, then your modem would also have to act as a DHCP server to give a separate address to the Obi and the router. (I think most modems can do this or be set to do this). Then your other other clients connected to the router and the router would be in the Double-NAT connection. I don't have any experience with double-NAT setups, but I think it would end up complicating your life more than you want :) For example, I think the OpenVPN clients have trouble dealing with double-NAT, so you may just end up changing one problem for another.
If anyone else has more experience here....please chime in....
