john9527
Part of the Furniture
43D4 is up....Development folderwon't run yet due to the SSL cert location issue on the fork (fixed in John's next build).
It’s called in start_apply.htm somehow (from memory). I don’t think the jquery.js itself is to blame. It’s the old webui that has the conflict.Ok so the jquery conflict I've avoided by hosting a known working jquery (hopefully). I've looked through detect.js but I'm not sure how that is being called to handle a page refresh.
Yeah I pulled down the source. Maybe I'll shop around for another fork-compatible router when lockdown is over so I can get some hands on dev timeIt’s called in start_apply.htm somehow (from memory). I don’t think the jquery.js itself is to blame. It’s the old webui that has the conflict.
Just to clarify....is it the router not getting an IPv6 address, or the clients?
Can you post a screenshot of your IPv6 page? and maybe the System Log/IPv6 page? (obscure any addresses)
Yeah I pulled down the source. Maybe I'll shop around for another fork-compatible router when lockdown is over so I can get some hands on dev time![]()
Working very well with the scripts. I am wondering if your method of detecting the user asp files could be adapted on Merlin as well to avoid the sed/mount of the menuTree.js. Also it would be neat to have the helper function receive a file argument plus a title argument and automatically copy/create the files under /www/user. It would need to be universal with Merlin though to avoid further fragmentation. I’ll nag about it after release and source push!43D4 is up....Development folder
Just a SMOP (Simple Matter of Programming)Working very well with the scripts. I am wondering if your method of detecting the user asp files could be adapted on Merlin as well to avoid the sed/mount of the menuTree.js. Also it would be neat to have the helper function receive a file argument plus a title argument and automatically copy/create the files under /www/user. It would need to be universal with Merlin though to avoid further fragmentation. I’ll nag about it after release and source push!![]()
Still using IPv6 smoothly on 43D4 in Native mode. Had some issues on my work laptop (Win10 1909) occasionally timing out on connections to the router (ssh and https), and sometimes DNS timeouts, but not on any other devices. Had to learn about IPv6 temporary addresses as well to understand the IPv6 Log showing multiple addresses per device. I also enabled the name resolution for fixed devices. And I’ve rebooted several times since Tuesday so the prefix has no issues being released I suppose.Enabled IPv6 just now. So far so good. Everything still works.
@john9527 do you know what version number you will be using for your next stable release please? I'm planning on pushing updates to my scripts in the next few days, and I'd like to add messaging/checks for your fork now that you and @dave14305 have very kindly sorted out methods for WebUI script supportJust a SMOP (Simple Matter of Programming)
What I did is really just a brute force approach. A helper function in c that scans the directory for .title files, if it finds one, reads the file and copies out the data into an array that's passed back to javascript. The javascript then parses that array and updates some other pre-defined arrays that control showing the menu/tabs. IIRC it was just less than 100 loc total. Actually, I'm sure that Merlin could improve it.![]()
Since dropbear and httpd do not listen on IPv6, could it have been that my PC was resolving the router hostname to the IPv6 address and failing to connect? I’ll pay closer attention next time I’m on that PC.Had some issues on my work laptop (Win10 1909) occasionally timing out on connections to the router (ssh and https), and sometimes DNS timeouts, but not on any other devices.
should be 43E5 or latero you know what version number you will be using for your next stable release please?
Hostnames for DHCP “static leases” are in the hosts.dnsmasq file in /etc. That file gets read by dnsmasq as an addn-hosts parameter.I set up the static lease in the LAN/DHCP page. But I can't find where to set up the DNS resolver for those devices.
Is it automatic (as in, if the device has a static lease, it's added to the resolver with it's name) or should I do it manually? If I have to do it manually, is there a page somewhere, or should I use SSH to change dnsmasq configuration?
The Advertise option is only relevant if a server is already filled in one or both of the fields. Otherwise, it just gives the router IP as the dns server. Note “...in addition to user-specified DNS”. If you don’t specify any DNS, it’s not relevant.Maybe the field "Forward local domain..." should be shown only when "Advertise router's IP..." is set to Yes?
Sorry...can't happen. Kernel is way too old.And if you have any information about an eventual Wireguard backport, let me know!
Yeah, that makes sense. I figured that much.Sorry...can't happen. Kernel is way too old.
Welcome To SNBForums
