Release [Fork] Asuswrt-Merlin 374 LTS release 45EC
john9527, so how can I run scripts and avoid this timeout or how can I increase it?
If your script is taking "several minutes" to run then it probably need to be redesigned or called from a different event. If that can't be done I suggest that you put all of those commands into a separate script (e.g. myscript.sh) and spawn it as a separate process:
# Run script now
/jffs/scripts/myscript.sh &
ColinTaylor, i need SD Card to be mounted when my scripts run, this is why I chose post-mount. If I will run them separately I will need to check if the SD Card is mounted and sleep until it is. Can you suggest the way to do it, also I wonder can you tell me the way to check if the ip_set module is loaded?
Bash:
modprobe ip_set
modprobe ip_set_iphash
modprobe ip_set_nethash
modprobe ip_set_setlist
ipset --create unblock iphash
Bash:
#!/bin/sh
until ADDRS=$(dig +short google.com [USER=52002]@localhost[/USER]) && [ -n "$ADDRS" ] > /dev/null 2>&1; do sleep 5; done
while read line || [ -n "$line" ]; do
  [ -z "$line" ] && continue
  [ "${line:0:1}" = "#" ] && continue
  addr=$(echo $line | grep -Eo '[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}')
  if [ ! -z "$addr" ]; then
    ipset --add unblock $addr
    continue
  fi
  dig +short $line [USER=52002]@localhost[/USER] | grep -Eo '[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}' | awk '{system("ipset --add unblock "$1)}'
done < /tmp/mnt/microsd/dnsmasq/unblock.txt
Bash:
#!/bin/sh
iptables -t nat -A PREROUTING -i br0 -p tcp -m set --set unblock dst -j REDIRECT --to-port 9141
The timeout is hardcoded at 2 min so currently no way to change it.
Just a warning about trying to do large scale 'DNS Poisoning' with dnsmasq. if that's what your are trying to do (Not sure what you are doing in your hosts-update-script) It really wasn't designed with that in mind and can get bogged down. I remember someone was trying to add 600,000 entries and it crashed dnsmasq.
You can still run your scripts from post-mount, you just need to invoke it as a separate process as shown in my example.
john9527, thanks for your warning. Updated my post with scripts. I have 264048 in my /tmp/mnt/microsd/dnsmasq/hosts.blocked and it seems to work just fine.
ColinTaylor, thanks, got it.
What about checking if the ip_set module is loaded, can you suggest me the way, please?
Also, I have a bunch of spam in log like:
Bash:
Dec  8 03:03:00 dnsmasq[30532]: failed to update ipset unblock: File exists
Dec  8 03:03:01 dnsmasq[30532]: failed to update ipset unblock: File exists
This is due to command I use:
Bash:
#!/bin/sh
    continue
  fi
Can you suggest how to avoid this spam?
Bash:
Bash:
#!/bin/sh
    continue
  fi
ipset has command line options to suppress errors like this. Is this available on your version?
-!      Ignore errors when creating or adding sets or
        elements that do exist or when deleting elements
        that don't exist.
john9527, I don't run Diversion, only installed entware with amtm to have TOR onboard. Not using Diversion.
dave14305, I guess not. -q maybe?
Bash:
RT-N66U:/jffs/scripts# ipset --help
ipset v4.5
Usage: ipset -N new-set settype [options]
       ipset -[XFLSH] [set] [options]
       ipset -[EW] from-set to-set
       ipset -[ADT] set IP
       ipset -R
       ipset -v
       ipset -h (print this help information)
Commands:
Either long or short options are allowed.
  --create  -N setname settype <options>
                    Create a new set
  --destroy -X [setname]
                    Destroy a set or all sets
  --flush   -F [setname]
                    Flush a set or all sets
  --rename  -E from-set to-set
                    Rename from-set to to-set
  --swap    -W from-set to-set
                    Swap the content of two existing sets
  --list    -L [setname] [options]
                    List the IPs in a set or all sets
  --save    -S [setname]
                    Save the set or all sets to stdout
  --restore -R [option]
                    Restores a saved state
  --add     -A setname IP
                    Add an IP to a set
  --del     -D setname IP
                    Deletes an IP from a set
  --test    -T setname IP
                    Tests if an IP exists in a set.
  --help    -H [settype]
                    Prints this help, and settype specific help
  --version -V
                    Prints version information
Options:
  --sorted     -s   Numeric sort of the IPs in -L
  --numeric    -n   Numeric output of addresses in a -L (default)
  --resolve    -r   Try to resolve addresses in a -L
  --quiet      -q   Suppress any output to stdout and stderr.
ColinTaylor, they were always there. Just decided to ask, 'coz I posting here anyways :)
I tested -q flag and that spam is still there. I think I need to test if the IP is in the IP_SET already before adding.
I have modified the script like this, but not sure how to modify in that awk part. Can you please help me guys :p
Bash:
#!/bin/sh
logger "unblock_ipset.sh: start"
until ADDRS=$(dig +short google.com @localhost) && [ -n "$ADDRS" ] > /dev/null 2>&1; do sleep 5; done
    if [ ! ipset -T unblock $addr ]; then
      ipset -q --add unblock $addr
      continue
    fi
  fi
  dig +short $line @localhost | grep -Eo '[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}' | awk '{system("ipset -q --add unblock "$1)}'
logger "unblock_ipset.sh: finish"
Bash:
#!/bin/sh
      continue
    fi
  fi
I suggest you create a separate thread if you want help debugging your script as the problems don't appear the be specifically related to this thread (i.e. release 45EC).
@john9527, thanks, but it's not the problem anymore. My first script is running without problems whilst it takes more then 2 minutes and now I know how to run other scripts. I will create separate thread for question how to deal with IP_SET better.
Thanks to all you guys and sorry for off-topic.
@Cromson, that's great! Which router though? :)
In my excitement, I forgot about the important stuff. ;)
It's an Asus RT-AC66U Rev. A1 that i bought back in 2016 and it's really working well with Johns Fork and OpenVPN.
As the main server i use an AC86U and i bought it because the AC66U would occasionally got really slow when more devices were connected to it.
So i thought with the AC66U left i give Merlin and the OpenVPN a try again and finally it worked.
For the record... i live in Mainland China, so VPN is a must-have, but also get it to work on a Router like finding the needle in the haystack! But I found it... ;)
Thanks again, great Forum with lots of useful information!!!
Hi everyone and especially john9527,
Thank you for all the help and support so far and for keeping my Asus RT-AC66U Rev. A1 alive.
I am currently on "374.43_45ECj9527" and all seems to be working ok except for the print server which has stopped working. I reverted back to "374.43_44EAj9527" and the print server works fine.
Can someone kindly check and confirm whether the "print server" option on "374.43_45ECj9527" is working please?
With kind regards,
