Release [Fork] Asuswrt-Merlin 374 LTS release 49E4
Hello, this started happening a couple of updates ago and i'm not sure if it's by design but when I SSH to the router the diversion autoupdate launches, before i was able to write commands. How can I change/fix this? Thanks for the hardwork!
Is there anything in /jffs/configs/profile.add or /opt/etc/profile that seems like it might be invoking diversion? Seems odd.
Strange indeed. The only recent change related to SSH was in rel 47 where I changed the MOTD slightly to include the build id. I wouldn't expect that anyone would key off that though.
may be a noobie question but how can't I access those files if i can go to the console. If I exit diversion the putty closes.
actually was like 3 updates ago, probably in the beginning of the year i didn't bother to find a solution thought might be a temporary bug or some weird interaction
If you eject/remove the USB drive does it let you login normally?
Now run
cat /jffs/configs/profile.add
ASUSWRT-Merlin LTS RT-AC68U 49E4 Sun May 2 15:55:32 UTC 2021
admin@RT-AC1900P-95F8:/tmp/home/root# cat /jffs/configs/profile.add
cat: can't open '/jffs/configs/profile.add': No such file or directory
But it's ok, anytime I need to use the console i'll just remove the disk.
If you plug the disk in while already logged in, run these 2:
cat /opt/etc/profile
ls -l /opt/bin
ls -l /opt/bin
admin@RT-AC1900P-95F8:/tmp/home/root# cat /opt/etc/profile
cat: can't open '/opt/etc/profile': No such file or directory
admin@RT-AC1900P-95F8:/tmp/home/root# ls -l /opt/bin
ls: /opt/bin: No such file or directory
That is after the drive had been plugged in again?
Is there a way to include all the traffic generated by a client when it is connected with a open vpn server?... In my rt-n66u with the old merlin firmware, 380.70, if I was connected to the vpn, my IP address was the same as the router and I was able to browse a geo-blocked site (...blocked for ip addresses outside the nation the rt-n66u is installed...); I mean: the rt-n66u was in Switzerland and the client in Italy; when I was connect to the openvpn configured on the router, the IP address of the client was Switzerland, and I was able to connect to a geo-blocked streaming service. With this 374 LTS, when the client is connected to the openvpn server, the IP address is italian; there is some parameter on the server or client side that I should enable?...
And another 50xx Dev working great! Some day I'll have to try these new features you keep adding...
Edit: It's 50D6
With the past few releases I've been experiencing random router reboots. Approx 2 per week.
I was on 48E2 -> 49D6 -> 50D6 (have been updating in the hope something in a newer build fixes it, but its still happening...
Please let me know what data/info I can supply to help diagnose this. syslog: https://pastebin.com/74ur05Wk
Please let me know what data/info I can supply to help diagnose this. syslog attached.
I only see one unexplained restart in your log. That was at 05:30 this morning. Do you have a scheduled rebooted configured?
I do, at 3am on a Sunday:
Yep, to clarify, I'm using an RR-AC66U and the log only shows the most recent occurrence as I flashed 50D6 earlier this week in the hope it might fix it... but then today another reboot occurred.
