Hello everybody,
i try to configure QoS on my router ( Firmware 386.14_2).
I enable QoS (with "enable QoS"), select traditionnal QoS and add my devices.
My problem is that, if i return to the network menu and go bak to menu Adapative Qos / QoS, the "enable QoS" button is set to Off
So i need to renable it, the router reboot (it seems so), log into it, and then i have the QoS traditionnal page to configure my devices.
but it seems that QoS is working (QoS wAN/LAN Bandwisth Monitor shows my devices)
Is it normal behaviour or a potential issue ?
regards
regards
