Maybe a simpler way to check...how do you handle Access Intranet? Potential changes to _ap_isolate would be at the same time as _lanaccess.currently it will be applied on either firewall-start or a restart_wireless event
on 384 I override what that does with my own ebtables and iptables rules, so I ignore whatever is set. I'll probably build in something to "sync" the isolate settings between my page and the stock page if your change is mergedMaybe a simpler way to check...how do you handle Access Intranet? Potential changes to _ap_isolate would be at the same time as _lanaccess.
You are describing the change that Asus made in the 386 builds (if guest network doesn't access LAN, turn on AP isolation). This is what is being fixed.Does anyone know if this thing will work out in the final version? Blocking the communication of machines on guest networks makes it impossible to use the entire guest network on IoT devices.
Same result as last test. I enable AP Isolation in the GUI, and both the variable wl0.2_ap_isolate and the GUI are not changed. You are very close to fixing this.@JWoo
Please give
RT-AX58U_386.1_beta2-gbdc1bdaa14
a try....and please bear with me as I may have more to learn about nvram management in the new scheme of things![]()
I'm just doing a bit of leg work to try and help out @RMerlin so he can focus on the bigger things. If/when we get something that works, I send it off to Merlin for his review and he decides how to proceed. I'm not doing a separate fork of his latest code.When you find the successful configuration, will you be making a PR to the main Merlin branch, or do you maintain a number of separate forks? (I did see the stickied thread in which you maintain a 374 fork)
ARGHHH!Thanks John for giving it a shot today! You are close.
NP. Will test real quick. Appreciate being able to help out.@JWoo
Interesting....the way they are handling instanced nvram (wl0.1, wl1.1, etc) for the guest network is really ugly. So much so, that as I started to trace back the required changes, I'm pretty sure it would have been something that Merlin wouldn't even consider implementing as it would change too much.
I gave it one more shot with a different approach that only makes changes in the gui page. Not sure if it will work, but a new build is up with today's date.
Thanks for your help....sorry I couldn't do more of the debug myself but just can't setup a Merlin router right now.
What happend this? Not ib beta 3 version...@john9527 you definitely have reserves of perseverance. Tested your latest g3274c93599. I did a full factory reset just to make sure I wasn't impacting the test in some way.
The Access Intranet function is working great and as you changed it only sets the lanaccess parameter.
The Set AP Isolated function does not work; the menu is not updated to Enable when that is chosen, and the ap_isolate parameter is not changed. The blank in the menu is corrected.
Wh
Welcome To SNBForums
