Hi all, have used hardware acceleration in the pass (CTF and FA)
which requires STP to be disabled for level 2 acceleration.
However in my router ax58u with latest firmware, I see that it writes
Archer: enabled
Flow cache: enabled
Even with STP enabled by default.
Questions:
1. Is this considered level 2 acceleration, or is there an even higher acceleration?
2. What happened to packet runner? Is it the same as 'archer'?
3. What is this archer?
4. Did asus/merlin change something such that level 2 acceleration can be reached regardless of STP settings?
Not all questions need to be answered, just answer what you know to the best of your ability and everyone can answer so this thread can provide answer to anyone who found this post.
Thank you.
Archer: enabled
Flow cache: enabled
Questions:
Thank you.
