Help appreciated for N66U/asuswrt-merlin
zyu4router
I upgraded RT-N66U from stock firmware (I reset stock firmware before upgrading) to asuswrt-merlin(3.0.0.4.376.49_4)
I noticed that Traffic Monitoring shows nothing. after checking seemed others do not have such issue. I then tried to downgrade to previous asuswrt-merlin(376.48_3). But still nothing shows in Traffic Monitoring.
Could anyone kindly advice possible solutions. Possible Hardware issues? Thanks in advace!
picture.php
First, other than this observation, does the router work well ?
picture.php
Anyone could advice if it is possibly due to that N66U must first update to latest Stock Firmware before upgrading to asuswrt-merlin???
Or
After upgraded to asuswrt-merlin, must erase NVRAM first???
Nobody has similar issue around the world...:(
Since you are not getting the scale markers or the summary data, this usually indicates a javascript error. Did you update your browser, add an adblocker or change your antivirus software lately?
Hi John9527,
Thank you very much... I never thought this could be possible cause as I can watch Traffic Monitor for my AC56U in Chrome.
In addition, both "System Status" and "Performance tuning" shows activities for N66U in Chrome as well.
Anyway, I switched to IE (instead of Chrome)... Wa La... I got traffic data...
picture.php
Although I am not sure why AC56U was not affected by Chrome. But problem solved...:)
Thanks again, John9527.
