Hello everyone, as you can probably see, I'm new here. I found this forum while I was searching for the answer to my question.
I am a Comcast user with a bandwidth limit of 1024GB data per month. I got an email from Comcast last month that I was approaching my limit of bandwidth. Since then, I have been researching network monitoring apps that I can install on my MacBook that will show me the device using all of the data being used, unsuccessfully. I sent an email to Securifi and asked them if there was anything they could do to assist. They told me they have an app IoT, but it will only work with the Almond 3. Frustrated with that answer I tried to find a solution on google - unsuccessfully. I downloaded a couple apps that are work, but not for the specific thing I need. I have the apps 'who's on my wifi' and 'PeakHour 4'. Peak hour does fine monitoring the total bandwidth, but I can only see the total amount of traffic done through the router - I can only see device traffic that I have PeakHour installed on, my macbook pro. I will be grateful for any help or direction you can send me that will allow me to see the individualized totals for each device going through my router. Thank you! Cheers.
MacBook Pro mid 2014 - 2.6 Ghz i5 - 8GB DDR memory
Almond + router
Almond range extender
Motorola MB7420 modem
Almond + router
