ASUS Unveils RT-BE88U WiFi 7 Dual-Band Router
Is this RT-BE88U WiFi 7 Router supported using asuswrt-merlin? @RMerlin ?
I am debating if i want to purchase it, or if i should go with any of these.
ASUS RT-BE88U - Wi-Fi 7 - 383,31
ASUS RT-AX88U -Wi-Fi 6 - 347,96€
ASUS RT-AX88U PRO - Wi-Fi 7 - 253,47€
ASUS RT-BE58U - Wi-Fi 7 - 229,19€
Asus TUF AX4200 -Wi-Fi 6 - 204,05€
ASUS RT-AX92U -Wi-Fi 6 - 153,36€
RT-BE86U
What is the big difference between the two? Merlin vs Gnuton?
None, just different maintainers. Gnuton is based on my code, just for different models.
Is or will TUF-BE3600 - 247,67€ be supported? @RMerlin
I didn't ask only if it would be supported, but if it "was" already supported.
All you posted was a link regarding "if".
I have no idea if it is already supported since a lot of models are supported under another name.
I am already aware of the "if" part.
No.
I already posted the "was" part and you chose to not read it for some reason.
Wrong models.
I posted another TUF model, but RMerlin already said no, so all good.
I'm still looking and considering my options.
I haven't moved into my new apartment yet, so i still have time :)
Just got a new PC with a 2.5gb network port, and the default ASUS firmware for this router includes iperf3.
So took the opportunity to do a little iperf run on this device.
Router->PC
Bash:
<user-omitted>@RT-BE88U-CA28:/tmp/home/root# iperf3 -c 192.168.1.145
Connecting to host 192.168.1.145, port 5201
[  4] local 192.168.1.1 port 34092 connected to 192.168.1.145 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec   280 MBytes  2.34 Gbits/sec    0   1.10 MBytes
[  4]   1.00-2.00   sec   272 MBytes  2.29 Gbits/sec    0   1.10 MBytes
[  4]   2.00-3.00   sec   281 MBytes  2.35 Gbits/sec    0   1.10 MBytes
[  4]   3.00-4.00   sec   279 MBytes  2.34 Gbits/sec    0   1.10 MBytes
[  4]   4.00-5.00   sec   280 MBytes  2.35 Gbits/sec    0   1.10 MBytes
[  4]   5.00-6.00   sec   280 MBytes  2.35 Gbits/sec    0   1.10 MBytes
[  4]   6.00-7.00   sec   281 MBytes  2.35 Gbits/sec    0   1.10 MBytes
[  4]   7.00-8.00   sec   280 MBytes  2.35 Gbits/sec    0   1.10 MBytes
[  4]   8.00-9.00   sec   279 MBytes  2.33 Gbits/sec    0   1.10 MBytes
[  4]   9.00-10.00  sec   279 MBytes  2.34 Gbits/sec    0   1.10 MBytes
[  4]   0.00-10.00  sec  2.73 GBytes  2.34 Gbits/sec    0             sender
[  4]   0.00-10.00  sec  2.73 GBytes  2.34 Gbits/sec                  receiver
iperf Done.
PC->Router
./iperf3 -c 192.168.1.1
Connecting to host 192.168.1.1, port 5201
[  5] local 192.168.1.145 port 55079 connected to 192.168.1.1 port 5201
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.01   sec   275 MBytes  2.29 Gbits/sec
[  5]   1.01-2.00   sec   279 MBytes  2.36 Gbits/sec
[  5]   2.00-3.01   sec   274 MBytes  2.28 Gbits/sec
[  5]   3.01-4.00   sec   276 MBytes  2.33 Gbits/sec
[  5]   4.00-5.01   sec   268 MBytes  2.23 Gbits/sec
[  5]   5.01-6.00   sec   271 MBytes  2.29 Gbits/sec
[  5]   6.00-7.01   sec   285 MBytes  2.37 Gbits/sec
[  5]   7.01-8.00   sec   281 MBytes  2.37 Gbits/sec
[  5]   8.00-9.01   sec   283 MBytes  2.36 Gbits/sec
[  5]   9.01-10.00  sec   280 MBytes  2.37 Gbits/sec
[  5]   0.00-10.00  sec  2.71 GBytes  2.33 Gbits/sec                  sender
[  5]   0.00-10.00  sec  2.71 GBytes  2.33 Gbits/sec                  receiver
iperf Done
Throughput seems alright. I assume not hitting 2.5gig exactly is due to encapsulation?
Router->PC
Bash:
iperf Done.
PC->Router
iperf Done
Nice, didn't know Asus had added iPerf3 to their routers. This also made me discover that there's a but in the latest firmware on the GT-AX6000 where speeds from the router are limited to 1 Gbps.
Down to £288.99 in the Uk at the minute. £40 more than the AX88U Pro (£244) and £10 less than the BE86U (£299)
I just ordered a RT-BE88U to tinker a bit. I'm mostly interested to see if the wifi range is any better than my RT-AX86U Pro which disappointingly has worse range than my RT-AC86U.
By the way, the UniFi equipment Sam is talking about at the end of the video is $403, Ubiquiti US store prices.
- Cloud Gateway Max, $199
- U7 Pro, $189
- PoE+ Adapter 30W, $15
It adds 6GHz band support, UCG-Max has a built-in 4-port 2.5GbE switch. Extra switch may not be needed. Extra AP may be needed for larger spaces. Single AP may have less coverage compared to home router. Two APs will have better coverage and aggregate throughput.
Some limitations of the above relevant to home use:
- U7 Pro has a cooling fan inside. In warm environments it may not be dead silent device. May be an issue for some home users.
- UniFi networks don't support WPS. Folks with WPS-only setup IoT devices have to use a workaround to connect their devices to the network.
