How is this possible AC5300 GPL 386 branch is not out
why cna't for the love of gof secure router.asus.com ???
check the screenshot:
Looks like you are using HTTPs to me. Wasn't that the goal? Lol.
If you mean the fact that it says it's "not secure", that is because you don't have a trusted Certificate installed.
But you are successfully using HTTPs as you described you wanted. What you mean to ask is how to you install a trusted certificate.
can you please help me ?
HTTPs Stands for is Secure HTTP.
http://192.168.2.1 is not secure.
https://192.168.2.1 is secure.
If your computer says it's not secure, it's because it doesn't have a trusted certificate installed.
The connection is using HTTPS and is configured correctly. You must now install a trusted certificate.
can you kinldy help me install it ?
the thing is when i try pixelserv, it says go to http://192.168.2.4/ca.cert
but when i go there
blank page
i cant download it....
or am i in the wrong diretion...
pleases guide me
all i want it 192.168.2.1 and router.asus.com locally be secured HTTPS
but when i go there
blank page
pleases guide me
I follow this:
https://github.com/moorn/pixelserv-tls
and i get the below error
fearz@RT-AC5300-7DC0:/tmp/home/root# cd /opt/var/cache/pixelserv
fearz@RT-AC5300-7DC0:/tmp/mnt/sda1/entware/var/cache/pixelserv# openssl genrsa -out ca.key 1024
Generating RSA private key, 1024 bit long modulus (2 primes)
e is 65537 (0x010001)
fearz@RT-AC5300-7DC0:/tmp/mnt/sda1/entware/var/cache/pixelserv# openssl req -key ca.key -new -x509 -days 3650 -sha256 -extensions v3_ca -out ca.crt -subj "/CN=Pixelserv CA"\
Error Loading extension section v3_ca
1024:error:22097069:lib(34):func(151):reason(105):NA:0:name=subjectAltName,section=@alt_names
1024:error:22098080:lib(34):func(152):reason(128):NA:0:name=subjectAltName, value=@alt_names
